Question about Kenmore 24042 Top Load Washer
Want spin all the way round
The washer was over loaded
  • 15,935 Answers
This is NOT for older models equipped with a wig-wag transmission that are BELT driven. Read the instructions thoroughly BEFORE attempting. This is a repair of MODERATE difficulty that can be accomplished easily if you follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, there is a Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. NOTE: Inspect the motor coupling. If it shows signs of wear, this would be a good time to replace it.
10. Install the new Drive Motor. Make sure all the black rubber pads are on the motor (there are four of them). These help to reduce noise and vibration. Also, make sure the white cardboard piece that covers the bottom of the motor remains in place. This is a splash guard to prevent water from splashing into the motor in the event of a leak or overflow. Now, line up the motor coupling correctly and place the lower motor retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
11. Reinstall electrical connector to the Drive Motor.
12. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
13. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
14. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
15. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
16. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Maytag washer
Put some electrical tape around the exposed threads.
Jul 22, 2014 | Maytag MAH6700AWW Neptune Front-Load...
My washing machine has just decided to stop before spinning and the dial continues to click round and round and round... Its still full of water...... What do i do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Indesit Washing Machines
Excessive shaking on spining , washer moves a round on the floor I have leveled it rght on the nose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 18, 2011 | Kenmore 44042 Front Load Washer
When the washer spins with a heavier load like towels or jeans, it makes a horrible sound off and on. It sounds like something rough scraping against another rough surface. Is this something my HVAC...
Sounds like the bearings may be going out. Quick check for bad bearings: Open door, grab spin basket lip, yank on it; up and down works best. If you can get your fingers on the white plastic outer tub lip try to determine if the metal spin basket is moving independently from the outer tub in any motion other than round and round. If so you're rear bearings are becoming worn and will be especially noisy under a heavy load.
Jan 06, 2011 | Whirlpool GHW9100L Front Load Washer
The "floating drum makes out of round knocking noise in spin cycl
On the bottom of the washer tub is a "balance block?" that the bolt has loosened on. Have GE come repair it. We just had it happen to us as well. If you don't get it repaired it will cause more damage to the washer and then it won't be covered under the warrenty.
Jun 01, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
Washer makes thumping sounds when spinning even without a load
Check under washer to see that you have not got a broken spring that is causing the drum to spin out of round.
Thanks for using FIXYA
Sep 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer does not work well on spin cycle admiral aav7000aww
No you need to check ur clutch, u can check it by running the spin cycle for a few minutes then shut it off and turn machine up so u can look under it. get a spray bottle with cold water and alil soap detergent, then spray the clutch with it, if it shows or steams up or sizzles then the clutch is slipping and bad. the cluth is in the center near the tranny, should look like a round siver pc of metal about 5 inches in diameter
Jul 18, 2009 | Admiral AW22 Top Load Washer
Tub spins out of round
When that happens it is usually because of a drum bearing problem, have it replaced before this damages more parts.
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24042 Top Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
