My feature comforts heater stopped working - Heating & Cooling
2 Suggested Answers
  • 1015 Answers
SOURCE: Feature comfort 20,000 btu ng
The first thing I would do is to turn gas supply off and thourghly clean burner and pilot . Blow out with compressed air if you can and clean all vents.
I don't know what area you live in but where we are in central KS. we have a problem with mud dauber wasps and three years ago my empire shop heater was doing the same thing as yours and it had a nest around air intake for the burner. Got rid of the nest and it works fine.
Don't know what type of heater you have but mine required case panel removal to find and repair problem. I hope this helps you. Thanks
Posted on Dec 17, 2010
I have a Masport free-standing Vienna gas heater. Am able to light the pilot, but can't turn on heater. It is linked to an external thermostat. Would this stop the heater being turned on. C
If your external thermostat is set lower than the temperature in your house the heater will not come on. Make sure your thermostat is set higher than the room temperature and the heater should work. You can do this as an experiment just to try the heater for starting up. Then set it to the temperature you want for comfort. Do not disconnect the thermostat unless it is broken. Your thermostat maintanes the comfortable heat in your house.
Nov 03, 2014 | Heating & Cooling
Heater stop working
Check for a fuse, if none or not blown it is probably broken. Also make sure plug outlet is working.
Apr 20, 2014 | Comfort Zone CZ-441 Ceramic Heater
I have a feature Comforts Oil filled heater It fell mover I grab it right away but now it does not seen to be working is there a reset on it
Dear friend I have a good suggestion for you used in heater furnace company in Toronto best solution your problem i sent link..............
High Efficiency Gas Furnace
Oct 29, 2013 | All-Pro Kerosene Garage Shop Heaters - All...
My feature comforts fan heater won't turn back on
Many plastic cased heaters are provided with a safety device (thermotemp) to protect it from over heating, especially fan operated type heaters. Once blown only a tecnician could replace it. You did not state what type of heater this is.
Jan 18, 2013 | Refrigerators
My comfort zone cz792 utility heater will come on and fan will blow and it will stop thn start then stop and was not doing this a week ago when i first bought it. what is causing this?
With the heater unplug from power source, check for continuity between the two terminals on the thermostat. If you get an indication on your multi-meter of infinity, then the contacts of the thermostat are working correctly. No indication of continuity, is probably because the contacts ofthe thermostat have burned out and have decrease in thickness, breaking the circuit. I know of no place in which you can find a replacement thermostat. The contacts on the particular heater where evidently designed of inferior material. I have had two and had the same problems with both. You get what you paid for.
Nov 18, 2011 | Comfort Zone CZ792 Electric Utility Heater
How do you change the temp from c to f on a comfort zone heater
1. the f/c feature funtions from only the power or set temp screens.
2. press f/c button to toggle between f and c
Jan 13, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
The car starts to over heat when it is stopped for more than 2 to 3 minutes. it also accelerates on its own and doesn't stop till it gets to 35 mph.
turn the heater upto full heat (no a/c)to see if the temp goes down if it does then change thermostat.(i assume the fan(s)work)regarding the car accelerating on its own this is an anti stall feature on most cars(not all)especially VW group,it is also very comfortable in heavy traffic conditions when you dont need gas to move.(put the car in 2nd and crawl along with the rest)
Sep 22, 2010 | 1996 Mercury Tracer
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
