Question about Kitchen Ranges
Model fgf334bgwj gas range oven will not operate. I removed the oven bottom plate and deflection plate , the glow bar turns on but no gas flows to ignitor? Is it the gas safety valve?
When the ignitor glows brightly and the oven doesn't light it is usually a defective ignitor. The way to know if the ignitor is good or bad is to read the amp draw of the ignitor with an amp or watt meter. The gas valve and the ignitor are wired in series and for the gas valve to draw the current the ignitor has to draw 3.5-3.8 amps.If the ignitor is drawing 3.5-3.8 amps the new gas valve is defective. If it is drawing less amps the ignitor is defective.
Posted on Jul 25, 2010
JGB900 oven won't work. Range top works, broiler works. No glow in oven. Regulator is on.
Your problem is with the oven ignitor. Remove the racks from the oven, remove bottom shelf. Remove the metal plate covering flame spreader. The igniter should now be visible. Turn oven on and watch the glow from the igniter. It will come on but it wouldnt get too bright, so it wouldnt open the gas valve. After changing the ignitor, oven should light.
Feb 17, 2011 | GE Profile JGB900 Gas Kitchen Range
Kenmore gas oven; range&broiler work, not bake cycle-bad ignitor?
Well there are other parts that control the igniter,but if you can remove the igniter and look for any cracks.Most are hard to find so you may need a magnifying glass.Any crack no matter how small will keep it from glowing.The gas will not flow until the photo senser has detected the igniter glowing for several seconds.You can get a parts breakdown at hope this helps.
Feb 02, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Model MGR4452BDB range top burners work but oven
    The igiter is bad and needs replaced . The glow bar has a crack and is not getting hot enough to open the oven valve allowing it to ignite.
    Nov 01, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
    Gas stovetop works but oven will not come on. Digital display shows that it is on but the oven does not come on.
    sounds like you have a bad gas ignitor. It is under the bottom plate and sits on the burner and is held in with 2 1/4 inch screws.8273075 should be the part number for your ignitor....the model number you gave is incomplete so it's hard to tell but hopefully that will help you out
    Oct 04, 2009 | Whirlpool GS460 Gas Kitchen Range
    Oven won't ignite, top burners work
    Faulty Ignitor, Check the ohms,if you don't know how to do this....change out the ignitor...this will fix it...
    Oct 01, 2009 | Frigidaire FGF334BG Kitchen Range
    Gas unit, top burners light, but oven will not light?
    The oven uses an electric igniter which needs to come on and heat before the gas valve will open. You can reach the igniter by removing the oven bottom (remove a couple of screws and lift it out) and then removing the baffle plate (one screw holds it). When you turn on the oven you should see the igniter glow if it's working correctly. If it doesn't, check it for visible breaks or test with an ohmmeter. A very high or infinite resistance means it's bad. If the igniter glows but no gas flows, the main valve would be suspect. A number of vendors online have parts available.
    Jan 09, 2009 | Whirlpool Kitchen Ranges
    Ligthing the oven glow bar
    you need to replace the oven glow bar take out the oven racks in the bottom of the range you will see two screws remove them remove the bottom oven pan under that is the flame spreader shield under that under it you will se the ignighter at the back of the burner bar just follow the instruct sheet with the ignighter to install and reverse just because the old bar glow-es don't mean its good just replace it
    Jul 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven, Broiler will not ingnite
    ok try this turn the bottom oven on count to thirty then smack the safty valve with the plastic end of a screwdriver its the square box with two wires on it that the burner tube goes to underneath if it lights replace it
    May 26, 2008 | Magic Chef 31100 Gas Kitchen Range
    Kitchen Ranges Logo
    336 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
