Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
The usb connector on my 500 gb seagate mseries is broken however i noticed that i can remove a plate on the bottom and replace the part my question is where can i get this part
  • astyndall Jan 25, 2009
    I have the same issue.
    REF: Seagate Free Agent Pro 500gb
    p/n: 9NL6A6-500
    with USB eSATA mSeries output card
    p/n: 100453518
    internal drive should be a 3.5 desktop hdd
    So we have 4 options...
    1- find the USB eSATA p/n:100453518 order it and pay shipping on a part that we already know will break easily ...
    2- buy a 3rd party 3.5 sata/usb drive enclosure / crack the seagate enclosure open and put the hdd in new enclosure.
    3- buy a sata to usb2.0 cable adaptor and use the sata out on the seagate untill it eventually breaks like the usb plug ... you should think about the possibility of the disslodged usb plug shorting out or damaging contact surfaces inside the output card... so if you can extract it with a pair of tweezers or forcepts to alleviate that concern.
    4- throw seagate 500gb drive away and buy a new one.. loose all data... spend more money
    I'm going with option 2
    - after opening usb eSata card (difficult but can be done by scoring glued edges with a razor knife until glue seam is penetrated... you will find that the solder joints for the usb plug are very small... so unless you have a 3M Work Station and the tool set for thhis type of solder operation...don't bother.
    - under usb eSTA card slot you will see no screws visible.. remove the 4 rubber feet on undercarraige to reveal 4 screws- remove
    - next you will find the power sup. and sata enclosure output card
    (p/n: 78S67597)- first remove 2 visible screws on the outter metal cover- remove cover, next remove 2 screws holding card in place - remove card and un-plug all 4 connectors and remove card..
    - now you will see the 3 base plate screws.. romove these
    -- now you should be down to just the vertical case without the stand (base plate)
    - pry open the case.. it will take some elbow grease and some cursing wont hurt but the extraterrestrial glue and plastic clips will give (and hopefully not break.. but if you're this far you shouldn't care about the structual integrity of the case anymore.
    - pull out the metal hdd case and set aside the plastic fantastic.
    - remove (and keep) COMAX dongle...
    - on the sides of the metal case you will see 4 rubber feet/spacers.. pull them off to reveal 4 more screws (13 screw thus far) save these 4 screws!
    - slide metal casing sideways to reveal a Seagate Barracuda 7200.10 rpm 500gb 3.5 desktop hdd
    Istall this drive in you favorite tower or newly acquirred 3.5 hdd USB external enclosure!!!
    ***put metal casing back on drive with the 4 screws you saved and re-plug in the dongle to keep dust off for safe keeping until drive is reinstalled in proper working enclosure or Desktop****
  • nicolasileso
    nicolasileso Dec 07, 2012
    Did the same thing than you, take it appart and plug it directly to the computer. Best way to solve the issue and free.
    Problem Solver:
  • 5 Answers
There are 2 other solutions to this problem.
First way is to find someone that has the other module P/N 100452909 Dual FireWire 400 and use FireWire instead.
Second is to pry open the USB module and have the USB connector re-soldered or replaced. The connector is similar to many of the smart phones, so a cell phone repair shop could probably replace it. Heck you might even have the connector replaced with the newer Micro USB connector or ask them to solder the USB wire direct to the interface board.
Posted on Sep 15, 2010
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to format my new seagate freeagent 500 gb with macbook?
Here is a link to Seagate that describes how to fromat your drive fro a Mac. GOOD LUCK!
Oct 14, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
The USB port on my seagate 500GB external drive has broken off, and is somewhere inside the case.
You should be able to pop open the enclosure to retrieve the hard drive. You may need to take out a few screws.
Once you've done that, you can purchase another external USB enclosure to replace the broken one.
Aug 09, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Computer does not recognize mY SEAGATE BARRACUDA 7200. 11 500 GB
Try using your SEAGATE Hard Disk on another PC , if it works then you have one of these problems,
1. Your USB Port in your PC (Or Laptop) is broken and you have to get another one*
2. You have a software problem (Try reinstalling your OS or scan for viruses).
3. The USB Cable has a problem (get a new one).
(*) some technician can replace your USB port or fix it, or you can buy a "USB Hub"
Jan 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
6,893 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
