Question about HP DesignJet 1050c InkJet Printer
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
  • HP Master
  • 1,121 Answers
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Posted on Jan 18, 2013
agnelkj
  • 210 Answers
SOURCE: Cannot run printer...stuck on Initializing
hi,
please go through the following link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01330821&cc=us&lc=en&dlc=en&product=390328
thanks and regards
agnel
Posted on Jul 25, 2008
  • 10 Answers
SOURCE: scanner error 20
your scanunit's lamps frecuenci is changed you should replace the scanunit
Posted on Jun 23, 2009
  • 1382 Answers
SOURCE: How can resolved Scanner error 12 in Hp Laserjet
Try to uninstall the software of your scanner and reinstall it again. Also
check your cables for loose contacts.
Thank you!
Posted on May 18, 2010
  • 142 Answers
SOURCE: HP Colour Laserjet 5550dn. Once
i hope that the problem is not in some of your printer boards, but i have to tell you that you have to expect problems with POWER SUPPLY BOARD or FORMATER BOARD. Please call service for help
pifonski
Posted on Apr 19, 2011
vinay229229
  • 1121 Answers
SOURCE: HP Designjet T1100ps 44-in Printer
Recommended for tec guys only:Error indication that service station error, open right cover check is there any obstacles in service station movement?.. check the service station connectors, if feel every thing is fine, remove service station, found dirty? remove motors, remove service station cover, clean entire unit with water, ensure that stocked ink entire should washed out, allow service station to dry, fix it up, apply grease for moving parts, fix entire back then try....for confirmation do the service test..** cleaning service station is dirty work but it will give good mileage, while cleaning take care of sucking tubes & drop detector unit.. Best of luck..
Posted on Nov 19, 2011
Z3100 error code 21.1:03
please get a hp skilled technician to have a look at the printer or give hp a call on 0860001030
Nov 07, 2013 | HP Designjet Z3100 InkJet Photo Printer
Hello! I have a HP Deskjet D1560 printer, and i have a problem with it. The power light blinks constantly, and the ink cartiges don't move when i open the case. Also, when i connect it to the PC it...
Remove the cartridges,switch on check initializing or not if initializing put cartridges one by one & find out which one faulty, if not initializing replace formatter...
Oct 01, 2011 | HP D1560 Deskjet Printer InkJet
Hp Laser jet M1522nf show" 52 Scanner error turn off then on" give me solution urgent
52 Scanner Error The product has experienced an internal hardware error.Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If a surge protector is being used, remove it. Plug the product directly into the wall socket. Use the power switch to turn the product on.
If the error persists, contact HP. For contact information, see www.hp.com/support/ljm1522 or the support flyer that came in the product box.
This is the internal laser scanner, if the error persists the scanner will need to be replaced by an HP authorized technician.
Jan 14, 2011 | Office Equipment & Supplies
Scanner error 20
Jun 20, 2009 | HP LaserJet M1005 All-In-One Printer
Hp designjet Z3100 photo plotter 79.04 error
It Seems It Could Be a issue with Formatter
but still We Can Do A Emergency Firmware Upgrade ,Mail Me For Detailed Steps
Apr 06, 2009 | HP Designjet Z3100 InkJet Photo Printer
DCP-130c error 44 Please Help
error 44 dcp 130/mfc 240/440 etc.:
abnormally high temperature within print head.
You have two choices to TRY to fix it:
1. put in new carts. press menu then start copy b/w then  fourtimes arrow up button (AUB) quickly one after another.
press by help of AUB and OK:
7 - (Ok) 6  - (ok) 4 (ok) then start b/w copy to initiate the carts and let the machine do some power cleaning.
leave the maintenance mode by pressing AUB 9 (ok)  and 9 again.
2. Make sure that the ph is at correct position simply by pressing on it from top (power up machine. wait til ph runs to left side. unplug from power. simpl press onto the ph). replug to power.
If you still receive the error the ph is defective due to bad generic ink and needs replacing.
Mar 21, 2008 | Brother DCP 130C All-In-One InkJet Printer
Hp scanjet 7650 urgent issue...
just reinstall scanner driver and software
Mar 20, 2008 | HP ScanJet 7650 Flatbed Scanner
HP DesignJet 1050c InkJet Printer Logo
214 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
