Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Code 12 on my water heater
How do I fix my problem with code 12 appearing on my Rinnia innfininity
  • 3 Answers
Code 12 is low gas pressure, or that the flame sensors are not picking up a flame, try removing the flame rods, in a rinnai infinity when you pull the cover off they are right in the middle, you can use a file to clean any carbon etc off,
Posted on Jul 31, 2007
RINNIA CODE 02
Google the brand and model number for the operating manual and look up the code and it's meaning.
Aug 23, 2013 | Rinnai E110CP Condensing Combination Gas...
Jacuzzi tankless water heater code 12 appears
For my Jacuzzi tankless water heater model #J-SN180F: It turned out to be an exhaust issue. If I take off the exhaust vent completely then the talks heater works with 3 baths at full hot water. I get the error code 12 again as soon as I put event an elbow of the vent. So my conclusion is I need some sort of straight vent.
Apr 22, 2013 | Water Heaters
My rinnia moldel 2532 wont kick on
Those units rely on a flow sensor. If you have water pressure problems it wont activate. If you have hard water, the flow sensor could be bad.
Apr 16, 2013 | Rinnai Water Heaters
Rheem rtg-66dv error code 12
Troubleshoot and error codes following link:
http://waterheatertimer.org/pdf/RTG-error-codes-3.pdf
Not getting gas, low gas pressure, air in gas line, igniter not aligned with burner, wires disconnected, unit not grounded ...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 10, 2017 | Rheem RTG-66DVN Direct Vent Natural Gas
F-12 always appear on monitor board
The "F 12" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
Nov 20, 2012 | Washing Machines
F-12 appear on monitor panel
The "F 12" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature. what you need to do to fix up your washer is to check on the wiring connection from the power supply to the water temperature indicator.
Nov 20, 2012 | Ariston Technologies Washing Machines
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
A code 041-345 has appeared on the dc 700 and the code is not in the xerox manual. What does the code mean?
we had the same problem. fuse f2 on iot board was blown. fixed it buy soldering a new fuse
vikas
agra
india
Nov 05, 2009 | Xerox DocuColor 12 Color Copier
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
655 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
