Question about HP LaserJet 5200tn Printer
13.02.00 paper jam in top cover area in LJ 5200
SOURCE: paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
Posted on Jan 17, 2008
SOURCE: HP 2430tn lj printer with 13.20 jam inside top cover error
This question is directed at Steve from the post above. I need to order the sensor you mentioned. Is that sensor located exclusively on the power supply (Part number RM1-1505-000CN)? Will I need to order the whole power supply, or can I order the sensor separately? It does not show it very clearly in the service and maintenance manual. Thanks for the help!
-Shawn
Posted on Nov 14, 2008
leroyal
  • 2120 Answers
SOURCE: lj p2015d paper jam light on, no jam
You probably have a jam in the fuser. Very hard to remove. Reply if you want to attempt dissasembly
Posted on Feb 28, 2009
  • 393 Answers
SOURCE: 13.20.00 Jam in top cover area, no jam
pull your fuser out and you will find the jam and reason for the noise. it is pulled from the rear 2 covers and 2 screws
Posted on Jun 23, 2009
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Posted on Aug 10, 2009
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
HP LJ 4L paper jam light flashes indicating a peper jam after printer makes a grinding noise. What can be the problem?
You may be right about the worn gear as a factor but I used to have a LJ 4 and whenever it indicated a paper jam it was always right. In some cases, the jam was a tiny scrap of paper deep inside. It took a flashlight and examination of every bit of the paper path to find it
Nov 02, 2012 | HP Black Toner for LJ4L & 4P
I have 5200 hp laserjet printer is a problem 13.05.00 jam inside top cover tell me this problem
A jam has occurred in the registration
assembly area.
1. Press the 'down arrow' to see step-by-step
information.
2. Open the top cover and remove the print
cartridge.
3. Remove all media inside.
4. Lift the metal flap and remove any
remaining media.
5. Verify that the media size matches the
tray settings and the dial on the tray.
6. Reinstall the print cartridge and close
the top cover.
7. To exit, press ? .
Oct 27, 2011 | HP LaserJet 5200 Printer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
13.20.00 JAM INSIDE TOP COVER
Without seeing the printer or knowing what you have already done....a "13.20 Jam inside top cover" error means that a jam occurred in the registration assembly area.
Remove the toner cartridge.
Remove all paper from inside printer.
You should see a metal flap. That's part of the "registration assembly".
Lift it up and make sure that all paper pieces are removed. Use a flashlight if you can.
Make sure that the media size that you are using matches the tray settings and the dial on the tray.
Reinstall the cartridge and try again.
May 18, 2011 | HP LaserJet 5200 Printer
Hello. i replace new fuser assembly of my lj 5200 but the paper comes out halfway and the printer stops with jam error. i reset everything, check all cables and sensor. they all in good position. is this a...
Replace the rollers. When the roller become smooth and worn, they do not pick up the paper well. Check all roller to make sure they have enough ridges. Purchase a maintenance kit for that model.
Mar 01, 2011 | Office Equipment & Supplies
Hp laser jet 5200 paper jam in fuser unit
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Aug 25, 2010 | HP LaserJet 5200 Printer
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Aug 10, 2009 | HP LaserJet 5200tn Printer
Replace your paper pickups and set your paper tray setting correct, both in the tray and the settings menu. That should help you out. The part# for paper-pickups is RF5-3739.
Mar 17, 2009 | HP LaserJet 4600dn Color Printer
HP LaserJet 5200tn Printer Logo
201 people viewed this question
Seeker5211
Seeker5211
