Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
I bougth a lcd samsung 40 inch tv. I cannot connect my gamecube input cables to my new tv. mY gamecube cable has 3 color, red, white and yello, but my tv input area AV IN 1 has only white and red. so when I connect into the AV IN1 area, a message pops up stating that there is no connection. PLEASE HELP!!
  • camborda85 Jan 26, 2009
    ohh no solution yet!
You need to get a special scart lead which you can connect your red, white and yellow leads to then connect the scart lead to your tv it should work then
Posted on Feb 01, 2009
Connection of bravia klv 40 with samsung note 2
yello is usually for video
white left audio
red right audio
but some cables have different config all i know that you could try switching yellow with white and see if works then
Mar 09, 2014 | Sony Klv 40X200A 40X200A Multisystem Flat...
Nintendo GameCube no color
Well you could get a DVD plAyer that allows you to hook up game consoles to it then for it to work properly or you could buy a new av cables then.
Feb 11, 2012 | Nintendo GameCube Console
I plug the white, yellow and red cables from the dvd player into the back of the tv but it says "no signal". I changed the input to Component 1 then I tried the other plugs too but still get the...
Hello
If you have connected the red, white, and yello video cable connection right correct to the respective pins; both at DVD and TV end, by selecting the input to Video-1 or Video-2, you must get the logo of the DVD player on the TV screen. Please not that whether you have 'Power ON' the DVD player. If the connections are good, the logo must be ther. Otherwise check the continuity of the RCA cable, of it may have damaged[shorted]. Try replace with an other cable. OK.
Aug 15, 2011 | Apex Digital LD4088 LCD TV
Samsung LN22C350D1D FACTORY SETTINGS??
1. Do what you did, enter to service mode, and reset to factory default.
2. Use the component cable (green, blue, red, white, red) connect your set top box to the TV’s component input.
May 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
How do i plug a game conlone to a direct tv box?
skate,
are you reffering to a game console connecting direct to a TV screen?
1st try to check if your TV screen have a terminal jack indicating "A/V INPUT" A/V stands for Audio/video. if the screen doesn't have this, you'll be needing A/V to RF converter
2nd if your screen does have a terminal jack indicating A/V INPUT the next step you need to do is: check your game consul cable it should have a 3 RCA cable having RED/WHITE and yellow marking.
RED and WHITE cable marking stands for "AUDIO"
YELLOW cable marking stannds for "VIDEO"
connect this cable to A/V input of your screen following the color code ( yellow to yello/ red to red/ white to white) then from the screen press a button indicating "A/V" or "INPUT"
cheers,
mark
Jan 29, 2009 | Toshiba 36A50 36" TV
How do I connect a Nintendo 64 games system to a Hitachi TV?
Hi kdg 1026,
The wire from the Nintendo should have 3 plugs on the end. Yellow, Whit and Red.
OPn the baqck of the TV you have inputs that are color coded, Yellow, White and Red.
Plug the wires into the color coded inputs.
Turn on Nintendo. Press input button on your TV remote until you get the picture.
Let me know if this helps.
Please rate this solution. Lone99star
Jan 27, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
How do i connect my dvd player?
It depends on what outputs your DVD player has and what inputs your TV has.
If your DVD player has HDMI outputs and your TV has a HDMI input then you will need to purchase a HDMI cable and connect the 2.
If either your DVD or TV does not have HDMI then you will need to move on to either a component video cable which has 3 cables on the end which are colored red, blue and green. You will also need to connect for audio which is a cable with 2 colors, red and white.
There are also s-video and the regular old way of connecting which is a 3 cable design which has a yellow end for video and a white and red end for audio.
If you need any more help or can offer more info on what connections your TV and DVD player have then I would be happy to help.
Jan 12, 2009 | Samsung LN26A330J LCD TV
I am hooking up a dvd player with the black and white wires
The most basic hook up you can do is use a composite AV cable(yello/red/white). This cable should have come with your player. Check your TV it has those available inputs. They are also color coded. On the back of your player, there is only one yellow colored jack so there should be no problem in identifying where to plug the composite video cable(yellow). Put the composite audio cables (red and white) to the DVD player Audio Out jacks (red and white). Then plug the other end of those cables on the back of your TV. Just make sure they are INPUTS on the TV and colored the same - yello/red/white.
Then find your TV's correct viewing channel. It is not channle 3 or 4. Depending on the TV brand, it may be called AV, INPUT, VIDEO, GAME, SOURCE, AUX, EXT., etc. To find that channel, you may need to check the instructions on your TV manual. Most of the time, there are buttons on the TV remote control or on the TV itself. Sometimes, you need to go into the TV Menu.
Mar 27, 2008 | Philips DVP5140 DVD Player
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
462 people viewed this question
Jerry Greenberg
Jerry Greenberg
