Question about Onkyo DV-S353 DVD Player
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
I,ve hook up all the HDMI plugs as shown on the Onkyo RV component hookup chart .The sound is amazeing watching thru the cable but I can't get any video or sound for my OPPO dvd player. I'm confused on the imput asignment it shows both a TV assignment and the HDMI3 I asign it to when I leave it on TV it shows the TV picture wtih a wide screen picture but with the HDMI imput it also comes up a boxed screen imputs, why does it have 2 assignments ? Then I'm not getting anything with my DVD , I have it hooked to HDMI3 from the RV to the DVD HMDI player like it shows, The RV HDMI out to in on TV HDMI also the Rv HDMI cable to the cable box . Why can't I get DVD audio or sound?. Am I not assigninh somthing right . Hope you can help I've been at it for 2 days. Karen
  • dennis May 11, 2010
    just unplug the cable box and try with the same configuration and i think it will work , i Heard somewhere cable boxs interrfear with this type of configuration using hdmi..
  • 4 Answers
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Posted on Mar 10, 2010
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Jan 10, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
I have just installed a HT-S6100 at home and works perfectly with a Blue Ray Samsung player (via HDMI). I also have a Sony DVD player with component cables I want to connect to my HT-S6100. I followed the...
There seems to be a lot of this type of lack of signal (video, audio or both) with this system. I have the same system and the same problem. Mine is working now. I'm using all HDMI connections. I think the other important thing to do is "delete" all Input Assignments that are not being used. By "delete" I mean set the Input Assignments to "----". Let me know if this helps.
Dec 14, 2009 | Onkyo HT-S5100 Theater System
Onkyo HT-S6100. Receiver says NO SIGNAL and so
I have the same exact unit and same exact problem. Any luck yet?
Oct 16, 2009 | Onkyo Audio Players & Recorders
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
I have a 40in sonybravia KDL 40v4100, 1080p. No hdmi and audio w
HDMI is a video AND audio cable. It carries both at the same time. Typically with a laptop, you have to go into your audio settings and indicate HDMI audio enabled / set ON or whatever your software has. If you use a VGA connection, then you would use a separate audio hookup say from the earphone out on the laptop to the VGA's audio input port on the HDTV. Its all in the settings on the HDMI capable laptop.
Jun 14, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
I like the look and price of the Marantz SR 6003 receiver, my only question being whether it suppports DSD data output from a SACD player like the ONKYO like the OPPO DV-980h. In other words can it receive...
Downloaded the user manual for the Marantz SR 6003 A/V Receiver. In this it stated that if a SACD player was connected to the SR 6003 with an HDMI interface earlier than 1.2 then the digital data from the SACD could not be transferred over the HDMI cable to the SR 6003. This implies, but does not confirm, that if a SACD player does provide a digital output on an HDMI 1.3 interface, then SACD audio data can be transmitted to the SR 6003 and, presumably, decoded and converted to 6 analogue streams which are then amplified and deleivered to the (6) analogue output terminals.
I'm fairly sure that the native DSD data from the SACD has to be converted to PCM before transmission over the HDMI interface which is better than nothing. What I was hoping for though was for the data to be transferred in DSD and converted in the SR 6003 directly to analogue, avoiding two intermediate conversions. This ideal solution can be done by only a few SACD/ A/V Receiver combinations, which is silly considering that it is also the simplest. One example, which has made a big impression amongst high fi enthusiasts, is the OPPO DV-980H Universal DVD player (plays any audio or video disc and costs almost nothing) and the Integra DTC 9.8 home theatre processor.
Jan 14, 2009 | Televison & Video
Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
Dec 12, 2007 | Oppo Digital DV-980H DVD Player
Onkyo DV-S353 DVD Player Logo
229 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
