Question about MSI RC410M-L Motherboard
System fan error
Hi i have a small problem for you to solve. Recentley i had a error warnig me that the system fan had failed.I have replaced the fan whith a new one but i still get the error telling me that the system fan is not working. what can i do to to correct this problem. the motherboard is a rc410-m rev 1.01 I would be greatful for any help you could give me.
thank you. Brian.
    Scholar:
  • 145 Answers
Just check that (1)you have installed the fan properly
(2)connected the supply to the fan correctly
(3) the fan is actually running when you switch on the PC.
also clear the dirt which has accumulated in the heat sink. While doing all this , ensure to use antistatic means.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Jan 26, 2009
Asus P8C WS error code 55
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
When a computer completely fails to boot or to provide any sort of power on self-test (POST) beep codes, the cause is either a hardware failure, lack of power or a bad connection.
To solve these problems, it helps to start with potential environmental causes first, such as a problem with the AC power being supplied to the computer.
From there, a good rule of thumb is to simply start disconnecting items from the computer one at a time until just the CPU, motherboard, RAM and power supply remain connected, and then swapping in known good replacements for them.
Test the AC power to make sure there is power to the outlet. Inspect the back of the power supply to ensure the power cord is fully seated, the power switch is on and the voltage setting is set to the right voltage, which is typically 110 volts.
Inspect the inside of the computer for any signs of burned components, such as capacitors or integrated circuits that are deformed or discolored, and replace the affected expansion card, motherboard, drive or other device if damage is located.
Verify a proper connection for each expansion card, cable, drive and stick of RAM by disconnecting and reconnecting each item without removing it from the system.
This can sometimes clean corroded or loose contacts and solve minor problems that prevent the system from booting.
Disconnect the drives and remove all of the expansion cards except for the video card, and try to boot with a bare system composed of only the power supply, motherboard, CPU and cooling fan, RAM, and video.
Attempt to start the computer again. If the system boots, reinstall the removed items one at a time until the system again fails to boot, and then replace the component that is causing the failure.
If the bare system fails to boot, swap in known good components for the motherboard, RAM, video card, power supply and CPU until the system boots.
Swap components into a working computer one at a time until that system fails to boot in order to locate problem components.
Hope this helps.
Nov 22, 2012 | ASUSTeK COMPUTER ASUS P8C WS - Motherboard...
Dear sir i have intel desktop mother board d845GRG but it no work the problems is board light is on but sir when i push power on button then not work processor fan , power supply fan i mean that my...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery make sure it is securely seated
hope this helps
Jun 10, 2011 | Intel D845GVSR Motherboard
Hi there, I'm using intel motherboard DX58OG. During my mother board bios update the system reboot and didn't come up. I have manualy reset and power of the switch and on back. still failed to...
Jun 09, 2011 | Intel BULK DX58OG ATX DDR31600 136610PK...
CPU over temperature error.solve it please
calm down
the CPU fan and heat sink are collecting a huge amount of dust the fan my looks it is turning but slower than normal
the heat sink is that metal fined bulk that have the fan at the top of it when the dust is filling the gapes between fins and under the cooling fan
it is easy to clean just unplug the CPU fan clean the duty heat sink first in it`s place dont remove it make sure all fins are clean so the air could flow and cool the things up
the fan in your hand remove the backside sticker you will find a small white plastic ring that hold the end of fan`s axial with small knife tip remove the ring then take of the blades of fan away clean them will with a small tissue clean the inner part of fan coils and so then bring a very littil mount of any thick cream hand cream or vasilien jelly lubricate the axial reassemblies you have a fan better than the new one and makes no any sounds
May 24, 2011 | Computers & Internet
I have an HP Pavilion a1730n. For the past 5 times I turned it on, I received an error message Error: The System Fan Has Failed!Service PC to prevent damage to the system.PressF2 to Continue I ran HW...
1. Check if fan is spinning. If not, replace with new one or check cables.
2. Check if there are no swapped fan connectors when reconnecting mb cables.
3. Check BIOS update on HP website. Choose your OS here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3339287&
4. Check for a BIOS setting for disabling the fan monitoring.
5. Install a monitoring app which reports fan speeds and temps. See http://www.cpuid.com/softwares/hwmonitor.html
6. Check if CPU fan works.
Mar 14, 2011 | Computers & Internet
My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem.My system Configuration...
There are different possibilities for system hang up. I want you to find it your self from following my simple instruction.
1. (when computer is turn on) Check temperature... overheating can cause system to hang up, it can cause the system to reboot, it can cause the fatal error message and turns your screen to blue. Overheating is cause by exhaust fan or blower not working. Find this blower or exhaust fan on top of the processor, as built in fan in your video card, attached on your power supply and on the casing of your computer. Replace non working fan or blower.
2. Check video card...faulty video card can cause your system to hang up. It can cause also your system to go on blank screen. Most common problem is loosen connection of video card from the motherboard. Disconnect and reseat the video card properly. Inspect the fan, if not working then video card will overheat and system fail. If you previously see moving colors in your screen especially small boxes, or discoloration and screen going black and white then it means video card is already failing. You will need to replace it.
3. Check for hardware failure. keyboard, mouse lan card can cause your system to halt and hang. You will need to disconnect this first when booting and see if by removing this hardware will complete the system to boot up to operating system. Replace faulty one.
4. Harddisk failure. when computer reset or will not boot up completely then hard disk usually cause this problem. Initial remedy is to reseat its connection sata, ide or power supply connector.
If you hear ticking sound in the harddisk or excessive vibration then it will need replacement.
5. Operating system corrupted. this can cause your computer not to boot up properly and hang the system. Reformat and reinstallation of operating system is required.
6. Power supply failure. you need to check the output voltage. dropping of voltage can be cause bi leaking capacitor in the power supply unit. replace it with exact value. Voltage should read +12VDC for yellow, +5VDC for red. and should be stable even with load.
let me know which one cause it.
Feb 07, 2011 | Intel D845GVSR Motherboard
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
if you download and install tune up 2010, it may fix your registry automatically for you however if it fails to, your operating system will continue to fail to shutdown or keep causing your system to hang at the f5 window which is the one your describing. Device drivers are very well known for causing this error and if you have installed a new device and your computer is not picking up the new device properly, then the computer will not shut down. There are several forms of viruses that cause the system to stay on, power problems may cause the system to crash during a storm and thus damage the computer registry. A system defragmentation, cleanup, along with a registry clean would be the first best ideas.
Jan 12, 2011 | Computers & Internet
Abit kn9 sli overheating ??
The problem could be a failed electronic component, and no cooling remedy will solve the problem. When some components fail, they result in high heat conditions.
Aug 01, 2009 | Abit KN9-SLI Motherboard
OVERCLOCKING FAIL/CPU FAN ERROR
First approach shold be the CMOS utility, check in FAILSAFE DEFAULTS that the error settings for shutdown are either null for overclocking or disabled if you don't have the failsafe defaults on your CMOS utility then set your settings to best performance (should be found on the main page of the CMOS utility). If you are unsure of touching the CMOs then you could try to remove the CMOS battery (small 3 volt battery about the size of a 20 cent coin) located on the motherboard this should reset the CMOS and fix the problem. hope i could help,thanks:)
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
System will.not post
Can anyone help me pls. fix my problem. My P5PE-VM Asus Motherboard having a problem error loading operating system. I replace my RAM, power supply and hard disk drive but seem's the error is not fix....I'm out of idea can anyone knows it and solve the problem.. I appreciate to thanks in advace!!!..
May 10, 2008 | Computers & Internet
MSI RC410M-L Motherboard Logo
368 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Mark Taylor
Mark Taylor
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
