Question about Sony Cyber-shot DSC-W70 Digital Camera
Mode switching when i try to change to auto adjustment or the other modes it bugs out and spins around the options. it rarely goes to what i put it on
  • angelz001 Mar 23, 2009
    My DSC-w70 is doing the same thing. I can take pictures from time to time, but the settings keep switching modes and going crazy. Does anyone know the fix?
Hmm i had this once when my camera (dsc-w70 ) was wet just heat up that dial JUST A BIT with a hair dryer or it maybe faulty > if so sony repair center
Posted on Oct 11, 2007
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
When I put it on M mode or auto mode it takes really horrible pictures, can't even see the picture, real bright.. When I put it on movie mode it takes great pictures but that is not good.
Usually when it is on M mode there is additional options you can adjust "manually" for good shots... It could just be that the options are adjusted not for the type of Pics you intend to make. Ex. It's set on low light when you are trying to take a high light exposure picture.
Apr 01, 2015 | Samsung Digimax S500 Digital Camera
How do I change the shutter speed on the Fuji Film Fiinepix Z20 fd
Instructions
Turn on the camera and rotate the shooting dial to one of the shooting modes, such as auto.
Press the "F-Mode" button to adjust frequent settings like ISO and picture quality.
Use the up and down arrow buttons to navigate between settings. Press the right arrow button to present the available options.
Use the up and down arrows again to adjust the settings option. Press the "Menu/OK" button to apply the change.
Exit the menu by pressing the F-Mode button again. Press the Menu/OK button while in shooting mode to adjust less frequent options, such as white balance and the auto-focus mode.
Use the up and down arrow buttons to navigate between settings, similar to the F-Mode menu. Press the right arrow button to present the available options.
Jul 22, 2012 | Fuji Finepix Z20fd Digital Camera
How do I switch off the feature that auto adjust the Brightness every 30 minutes - Its a samsung le37r888d - tanks
The TV is in whats called Shop Mode or Store Demo.
To remove this, you can etiher go back through the Plug & Play option via the Menu and Setup option.
Alternatively, if you press the Volume + on the side of the TV, then press and hold Menu until the screen goes blank, this will change the TV to Home Mode or Home Use and stop the settings resetting every 30 mins.
Jul 15, 2009 | Samsung TSK2792F 27" TV
My Zen is stuck on DJ mode and Shuffle mode. HELP!
Hold down the back button until a little gray screen appears. Then scroll down to Play Mode and select normal.
Jul 03, 2009 | Creative Labs Creative Technology Zen MP3...
Akai PT5250A - I cannot converge correctly.
this fixed this problem
Plugs on the chassis coming from keyboard and side video input are switched (they have same plug)
redoo convergence save and auto focus in factory mode after switching plugs
Jan 13, 2009 | Akai PT5250A Television
No high speed spin cycle
I just had a similar problem. The washer would just shut down prior to the high spin cycle. I had a service guy in and he had a diagnostics sheet. Did you get an error code? If you have the electronic. Turn the knob to the Drain/Spin mode and press both the "Options" and "Cancel" buttons simultaneously until all control panel lights are lit and flashing. Then turn the knob clockwise in click and the washer will then go into its diagnostics mode. With every click it should do something (i.e. fill, pump, drain, spin, etc..) continue turning 1-8 clicks. On the 9th click you should then get an error code. My code was E47, which I have already posted another possible solution. I could be either the door switch or the control panel. Remove the door switch by removing the wire around the rubber seal, then remove the 2 screws for the door switch and unplug the 3 plugs. Check the readings on the PTC (white plug on doorswitch). If the switch reads around 1500 ohms, then the problem is most likely the control panel.
To exit the diagnostics mode, the easiest way is to unplug the washer, wait 10 seconds, and then plug it back in.
The reading on my switch was 1398 ohms, which is close to 1500, so I ordered a new control panel. Hopefully, this will work.
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Sigmatel s90 switch off
sir, my sigmatel s90 phone had gone to flight mode but after putting a code it display some options ,i select one of them and it goes to switch off and on switching it on its keypad just blink pls help me
Oct 10, 2008 | Handmark Software MobileLists (950142) for...
Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Aug 19, 2008 | Princeton Digital VL173 Monitor
MODE SELECTION PROBLEM
Try menu-> setup->setup1, initialize, ok- this resets calendar and time as well. It brought mine back to correct mode selection.  Also make sure your battery is fully charged.
Jul 21, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
