Question about Refrigerators
Have an Intertek PTC-2000BR stop oscillating
The product stopped oscillating
Has stopped oscillating. How do I repair it?
Under normal conditions, cars should not oscillate. If your car is oscillating, what is the frequency?
Oh... and when you re-post your question, INCLUDE THE YEAR, MAKE, AND MODEL of your oscillating vehicle.
May 11, 2015 | Cars & Trucks
I have a Holmes HAS1650 stand up fan and I need to know how to get it to quit rotating.
Not sure what you mean by "stop rotating"
I assume you mean to stop oscillating. There should be a knob on top of the motor housing that you push down to oscillate and pull up to stop oscillating.
If you mean to stop the blades from spinning there should be a fan speed control knob on the top of the motor housing that you turn to "O" to stop the fan.
Here is an instruction manual for a similar fan...
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-holmes-products-Site/Sites-holmes-products-Library/default/v1405596036669/documents/instruction-manuals/HASF1515R_HASF1516R-UC_11EM1.pdf
Jul 18, 2014 | Dryers
Football intertek popcorn maker
Intertek is a product testing, and certification company. Their name on a piece of equipment means the inspected that model for electrical and sanitation standards used in Europe.
They are not the maker, and there isn't a question here.
Mar 29, 2013 | Kitchen Appliances - Others
Refrigrator stop cooling
if the whole unit has stopped cooling then its the ptc overload relkay on the compressor,simply replace it by unplugging it off the compressor and putting on an exact replacement ptc
May 02, 2012 | Refrigerators
My intertek oscillating tower fan is not blowing. Oscillation feature still works....any ideas. model FZ-5
i have a intertek ocsolation fan i checked the fuse its good no power to unit
Jul 12, 2011 | Heating & Cooling
Both freezer and fridge stopped workin. only the
make sure the overload relay and start ptc are properly connected to the compressor.also check the wiring. if the wiring is good either compressor is no good or you need to replace the over load relay and ptc switch.rare occasions the thermastat switch needs to be replaced.i hope this helps your problem.good luck i would like to here how things went for you
Jan 21, 2010 | Frigidaire Refrigerators
Chest freezer, stopped freezing, Ptc relay attached to compressor has overheated to point of partially melting.
Some of the PTC relays just give out for no apparent reason. (the brown ones more than any other) But in your case you can see physical signs of overheating. I would suspect the compressor has seized up, or has a shorted winding.
Jan 10, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Oscillation stopped working!
Sounds like the drive gear is stripped.
Nov 20, 2007 | Bionaire BAP1500-U Air Purifier
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
