Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
Too much water
So how do I reduce the water supply?
    Novelist:
  • 189 Answers
The humidifier is designed the use a specific amount of water. Slowing it down can reduce its efficiency. It can also allow mineral deposits to build up faster.
If you must slow down the water. Simply close down the saddle valve slowly untill you reach your desired amount.
Good luck
HVAC Teacher
Posted on Mar 09, 2009
I need to change the water panel on my humidifier but don't know where to turn off the water supply. Any ideas? Thanks
Hello, the water supply should be shut off at the saddle valve. I will post a pic of the saddle valve.robhvac47_11.jpg
Jan 26, 2011 | Aprilaire 700 Humidifier
I just installed a Hamilton whole house humidifier but am not getting enough water to the filter. The solenoid is opening for 2 seconds every minute to release the water as it is suppose to do, but the...
Most humidifiers have a strainer on the inlet side of the solenoid valve, if this strainer is clogged up it will reduce the water flow to the humidifer. Usually sediment builds up in the strainer and all you need to do is remove it and clean it up and reinstall it.
Jan 19, 2011 | General Filters 1099-LH Humidifier
I have a Honeywell humidfier HE 220A with a KIP U147112 pump. A lot of water bypasses the humidifer and I use 5 gal. in 24 hours. is there an adjustment on the pump to reduce the flow, or some other...
I have a Honeywell humidfier HE 220A with a KIP U147112 valve. Will turning the large screw head on the valve decrease the volume of water flow through the humidifier. Too much water is being wasted.
Dec 20, 2010 | Honeywell HE220A1019 Whole House...
Humidifier Water antibaterial additive
Hello. Humidifier water tanks must be regularly disinfected to remove the presence of bacteria and reduce the risk of mold spores. Carefully remove the screw-on cap, fill with cool water and add a tablespoon of household bleach to the water. Replace the cap and set aside for 20 minutes. Once done, empty the water tank, rinse thoroughly with clear cool water, and wipe the outside with a soft damp cloth and you are good to go. Do this once per week. Regards, Joe
PS please rate my answer. thank you.
Jan 06, 2010 | Crane Panda 1 Gallon Humidifier
No steam output
Dec 06, 2009 - found solution: if unit is truely clean, unplug unit then mix about a teaspoon of iodized salt (table salt) to the water. Reconnect unit wait about 1 - 2 minutes, unit will start to make a grinding sound but shortly after steam will produce.
Nov 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Aprilaire 700 using too much water-------
There is a small oriface that is installed next to the solenoid valve. It sounds like this oriface is missing. It reduces the water flow through the humidifier when it is working properly. You should be able to disassemble the solenoid fittings to check and see if the oriface is in the water line. For a "temporary" fix regulate the water pressure down by closing down on the saddle valve.
Good luck
HVAC Teacher
Feb 25, 2009 | Aprilaire 700 Humidifier
Too much water running through to humidifier
With the Honeywell he220, you will use alot of water, trying to turn down the water will only reduce your amount of humidity in the home, you may be able to adjust it a little but you need to take the cover off and reduce the water flow a little at a time watching the water as it flows across the pad, you just have to make sure the humidifier pad is getting plenty of water across it, to little and you lose your humidification, hope that was helpful to ya, thanks for your question,
mr.grzz
Jan 25, 2009 | Honeywell HE220A1019 Whole House...
Leaking humidifier
Check for an obstructed drain line.
Feb 28, 2008 | Aprilaire 700 Humidifier
Works too well, can't stop windows from sweating!
I don't know much about humidifiers other than they are rarely needed and most folk around here would rather there was a lot less humidity., especially considering how easily black mould grows and how injurious to health that can be.
Those few people living with an unsuitable heating system in a badly designed house usually find it is adequate to have a water feature in the lounge or to balance a bowl of water on a radiator.
Certainly when the windows sweat to such a degree, especially if you have double glazing, the humidity must be well above the comfort range, above 70%, and probably well into the moist range of 80% - 90%. Higher than that and any exertion becomes decidedly unconfortable...
I am guessing the humidistat is either faulty or cannot work because the humidity is already too high. I suggest you need to check the humidity in your home with an accurate independent humidity meter before you go further...
Mar 24, 2017 | Honeywell HE220A1019 Whole House...
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
221 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
