Question about Garden
Kohler pressure washer leak from the pump
Water is leaking from the pump
    Scholar:
    New Friend:
  • 90 Answers
Seals bad
Posted on Jan 22, 2013
Coldcut
  • 1554 Answers
SOURCE: karcher pressure washer leaking oil
all 4 stroke engines have oil, and 2 stroke can have a oil mixer reservoir to mix with engine gas or to lube the chains , gears, pumps.
If yours is 4 stroke as likely then the oil may be leaking at the seals to the main. (bad news)
Pressure wash it (lol) and locate the leak,
to speed up the leak you can pump some compressed air into the engine (be creative)
Posted on Apr 13, 2008
  • 33 Answers
SOURCE: water leaks out at water pump and i just replaced the o-ring
you may have cut o ring when you replaced. coat with vaseline next time before assembly.
Posted on Apr 21, 2009
  • 92 Answers
SOURCE: pressure washer won`t pressure up
Dear rustrick281,
It seems that your pump needs a good service. The sucktion and delivery valves got faulty. The high pressure seals and the low pressure seals must be renewed. The pistons must be checked for corrosion and cracks. Also the pistons or one of the pistons got stuck due to oncorrect lubrication. The swash plate that drives the pistons could have got loose. So the motor turns and the pump stays dead. So a good examination and service must be done to the pump. To renew all the parts I have mentioned, you must buy a PUMP KIT for you model. The pistons are not included in the pump kit....but hopefuly the pistons are still good. Also the oil inside the pump must be renewed.
Regards,
Fulltech.
Posted on May 07, 2009
  • 104 Answers
SOURCE: pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
  • 497 Answers
SOURCE: durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Posted on Aug 12, 2009
What does it mean when water leaks from the bottom of the pressure washer
Most likely the o-rings and packing for water side of the pump is bad.
Depending on the age, wear, and if it is a vertical or horizontal version. It more cost effective to just replace the pump sometimes especially it is a vertical style and under 3000 psi.
Jul 10, 2015 | Garden
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
My pressure Washer Pump Leaks water and does not pump normal?
If the pump is leaking water then you have a packing issue. this will cause a loss of pressure as well...check out here for parts Pressure washer parts catalog quick links Pressure Washers High Pressure... also check out here for specs and diagrams http://www.arnorthamerica.com/pumpbd.html
Aug 27, 2014 | Annovi Reverberi Garden
My 2500psi pump leaks what can i do?
sounds like the seals and o'rings are worn and causing the pump to leak water.also one of the pistons might have a crack in them.dis assemble the pump and inspect the pistons,if none are cracked,then replace all the o'rings and seals.this should stop the pump from leaking.
Jan 15, 2011 | Honda Pressure Washer PSI 3000
Oil and water comming out of oil filler stem
You have a seal on the pump between the pump and the water pump thats leaking you have oil and water mixing . I owen three mechines and i don't understand what you mean when you say the oil filler stem. I also rebuild power washers and pumps. If you can clarify where the water and oil mixture is comeing out then i can tell you excatly what the leak is thanks
Jan 09, 2011 | Comet BXD2527 Pressure Washer Pump
Pressure pump keeps pulsating when trigger not pressed
There is orobably a minor water leak on the output side of the pump. The pump is sensing a pressure drop due to the leak so it will run for short periods to maintain the pressure i the output line.
Aug 20, 2010 | Karcher PSI Electric Pressure Washer
KOHLER HYDRO 13 When pressure washer engine is
first sheck the inlet screen where the garden hose attaches,if there is water flow then see if it has a manual pressure regulator, this will be a knurreled knob somewhere on the intake manifold of the pump, ifyou have one, turn it clockwise and see if there is a difference. If still no luck, disconnect the high pressure hose from the pump, start it and see if warer flows at that point, Your gun may be clogged or your hose may be delaminating on the inside and need to be replaced. If all this fails I suggest you bring it to an expert. These pumps can require special tools and expertise to repair internally
Nov 08, 2009 | Karcher 2500 PSI Pressure Washer
Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Jul 22, 2009 | Honda Garden
Water leaks out at water pump and i just replaced the o-ring
Apr 10, 2009 | Karcher 2500 PSI Pressure Washer
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Mar 21, 2009 | Karcher Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
