How to change region on Xerox Phaser 6000,6010, WC 6015. I now, that must be programming IP Board, but how?
  • 18 Answers
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
SOURCE: xerox phaser 7750gx
Hiya,
Can you be more specific regarding the Engine Logic Board Failure as in is it timing, rom/ram, micor pitch or NVRAM as code 80 is a failure code for
Engine Firmware Halt Failure .
Ta
Posted on Nov 03, 2008
  • 110 Answers
SOURCE: Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Posted on Jul 24, 2009
  • 141 Answers
SOURCE: Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Posted on Aug 04, 2009
  • 8404 Answers
SOURCE: How to find the ip address for Xerox phaser 8560?
Is this a network printer?
I would normally expect a network printer IP address to be assigned dynamically assigned every time it comes online.
Posted on Dec 16, 2009
CRUM ID 093-926
That error signifies an unsupported black toner cartridge. Verify oem Xerox cartridge, try reseat cartridge. If not cartridge it will be the MCU Board, part number 960K60951.
http://www.iteminconline.com/960k60951_062k23373-960k60951-xerox-workcentre-wc6015-engine-controller-mcu.htm
Jan 31, 2016 | Xerox 6015/NI New Workcenter 6015/NI Laser...
Im getting an error not a genuine xerox product on my xerox phaser 6250
You may have gotten a cartridge meant for another region. Like Canada or Europe, I have seen it happen. Call them and ask for a replacement.
Mar 03, 2010 | Xerox Phaser 8400 Laser Printer
Problem connecting to Xerox phaser 3124
sounds like you need to get into the firewall and go to exceptions. Once there you have to enter the IP address of the printer so it will make an exception and allow the data to get to the printer. You can probably ping the printer, but if it is being blocked it will not allow data.
Another thing to try is to make sure you have the printer setting of DHCP off and set to manual so the address is static, or stable. But with DHCP selected it is not uncommon for Phaser printers to search the network and reset it's own IP address. Have seen that a lot, any reboot or power on power off will change the IP address by itself.
Let me know .
Jan 18, 2010 | Xerox Phaser 3124 Printer
Dec 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox 3545 offline
Did you set the IP address to Manual ( Static) to set up a permanant IP address? If you left it on auto and DHCP settings wrong, it will search and reset the IP address. Run a configuration report and check to see if you IP address has changed, I bet it has.
Jan 22, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser Networking
Have you tried just reinstalling from original Xerox CD. This worked for us in a similiar situation.
Oct 12, 2007 | Xerox Phaser 8400 Laser Printer
Print jobs are not getting queued.
This is late but most likely the IP address is set to DHCP or auto and the printer is changing the IP address.
You need to set it to manual, and set the IP address static.
Those machines will change the IP address by itself.
Sometime even when you have set it manually it will change back to auto.
Feb 19, 2007 | Xerox Phaser 7400DN Laser Printer
682 people viewed this question
k24674
jasbo
jasbo
