Question about Kenwood KDC-MP228 CD Player
CANT GET POWER FOR MY SYSTEM
I HAVE A BANDPASS BOX HOOKED UP TO MY KENWOOD WITH A ALPINE AMP MY BOX WAS GOING IN AND OUT THEN I LOST POWER TO MY WHOLE SYSTEM I CHECKED ALL MY FUSES AND THEY ALL LOOK GOOD...CAN ANYONE HELP ME WITH THIS PROBLEM?
  • Juan Jiminez Jul 16, 2007
    yes it was a fuse problem thanks for all the help one of my fuse connectors was loose.
    everything is back up and running!
  • 48 Answers
Make sure you check all the fuses, this means the fuses on the radio Red and or yellow wire, the ones in your fuse panel, The ones under the hood, (if any) the fuses in or connected to your amp. The best way to do this if you do not have a volt / ohm meter is to buy new fuses of each typ used in your sustem and just swap them out. As you say your whole system is dead including the Head Unit (radio) after replacing the fuses you will need to check to see if all the wires to the radio are still properly connected especially the grounds. If every thing above checks out then you have a dead radio and it will need to be replaced. Again as you say the WHOLE SYSTEM is out I assume you mean the radio as well.
Posted on Jul 14, 2007
I have an alpine mrv-f307 4/3/2 channel. I have it hooked up to 2 12in Kenwood subs. Right now standard 2 channel each sub having their own. I heard doing a series hook up and bridging the subs to the amp ...
Bridging an amplifier refers to combining the power of two channels to run one speaker at higher power. If it is wired correctly, your amplifier is running with 4 channels bridged into 2 speakers now.
Mar 11, 2015 | Kenwood Car Audio & Video
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
I have 2 15 type r subwoofer and 2000w alpine amplifier i like know if this dual 15 bandpass can handle?
Check the specs on your speakers and the amount of cubic space it needs to breathe and amount of porting required and then check the box to see if it meets that requirement otherwise if it doesn't it will sound like **** and be highly distorted.
Dec 10, 2010 | Dual 15" Bandpass Sub Box Enclosure Plexi...
My dual speaker box has lights but they dont turn on i have tried hooking the power to the amp but still no luck
they should need power and ground! if they do not come on might be burnt out! Lights in and on boxes burn out fast cause of all the vibrations!
Oct 22, 2009 | Dual BANDPASS 12 " SUB BOX ENCLOSURE...
I really dont have a problem, moreso i am trying to figure out if the speakers that I am wanting to get are compatible with the amp, and if they are going to sound good.
what amp and what woofers???
basically as long as your amp has enough power to run the woofers the system will work but factors such as box type, vehicle, woofer direction, amp tuning, etc. will have more effect on the system as a whole. so here is some basics...
> what kind of vehicle?
> what kind of box (sealed, vented, bandpass, etc.)?
> what kind of music do you listen to (how much rap in percentage of all music you listen to)?
> what head unit, amp, and woofers?
> how much bass are you wanting?
> are you building this system on a budget and if so how much are you expecting to spend?
that is a good place to start in my opinion.
Aug 16, 2009 | Mac-Audio Car Audio & Video
I HAVE TWO 15" MEMPHIS SUBS AND A POWER ACOUSTIK 1440 AMP. I AM PUTTING THEM IN MY 2002 SUBURBAN, WHAT IS THE BEST BOX TO USE? PORTED OR VENTED
that mainly depends on the type of music you will be listening to. If you need clean, punchy bass, use a sealed box. For more growl, and louder bass, use a tube ported or slot ported box. I would not recommend a bandpass box for 15"s but they do make them. I have 2 kenwood 12"s in seperate slot ported boxes with a SPL 1500 watt amp, making about 149Db in a 93 Eclipse. Let me know if this helps :)
Jun 15, 2009 | Lanzar OPTI1222D Car Subwoofer
I just bought 2 12 incch explodes the xs-l126p5 modle and i have a 1000 watt explode amp xm-1652z modl. in a bandpass box. it dont sound the way i expected to. if you can help...
Did you have it hooked up by a professional or did you (or someone you know) do it. If a shop/pro didnt do it make 100% sure everything is hooked up right. Increase the size of your power wire from your battery to the amp. Check your gain settings on the amp. If the vehicle you have this in has a trunk (not a hatch back), position your speakers against the back seat facing you as your putting them in the trunk. If none of this works, buy bigger speakers and more power!
Jun 15, 2009 | Car Audio & Video
Blue illumination doesnt work
unscrew the plexiglass and try to get to the light and mess with it to see if it shook something loose, if that doesnt work, you might have to buy a new light....hope this helps!!
Mar 21, 2009 | JC Whitney - Dual Illuminite 12" Bandpass...
My kenwood amp wont push my 10" rockford falsgate punch sun
It sounds like a bad ground, I would go through all your connections
Jan 07, 2009 | Alpine CDA-9885 CD Player
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Kenwood KDC-MP228 CD Player Logo
93 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
