Photosmart All-in-one printer
I'm getting a pop-up that says Fatal error during installation... the overal progress is at 96%. When I click okay it all goes away - only to pop up again and again. I can print to the HP just fine. I think it has something to do with the Kodak EasyShare printer dock... maybe they just aren't compatable????
Any advice?
  • Anonymous Mar 21, 2009
    I'm getting a pop-up that says Fatal error during installation... the overall progress is at 96%. When I click okay it all goes away - only to
    pop up again and again. I can print to the HP just fine. Uninstalling and reinstalling the software doesn't help.
I uninstalled the software for the HP and the Kodak EasyShare... then re-installed the software and the drivers. Seems to have worked.
Posted on Jan 26, 2009
Error message fatal error during
make sure its compatible with computer before installing because you computer need to recognize the printer after you pluged the printer with computer
Oct 14, 2009 | HP Photosmart D7460 Printer
Fatal error when installing HP Officejet 8500, fails at 96%
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and try the step mentioned below
insert the cd in to the computer and then go to computers and right click on the cd icon and open it now you will see a Util folder open it and then open CCC and in CCC you will se some files like uninstall_L2, Uninstall_L3, Uninstall_L4
if you have a HP computer then open uninstall_L3 and continue to clean the printer entries If you do not have a HP computer then open UNINSTALL_L4 and continue
after cleanup restart the computer and then go to c drive >>Program files >>HP and delete the digital imaging folder
now install the printer software once again if you still get a fatal error at 96% then do not click on the ok button of the error screen directly restart the computer and when it restarts go and try to print in will print fine
and still if you have any problem then you can call the HP helpline for free support that is 18004746836 24hrs support
Sep 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Get 'fatal error' during HP C4599 install
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and at what % you get the error is it at 18 % 32 % 56% 94% or 96 % if you get the error at 96% followthe step mentioned below or else please tell us the % at which you get the error
Sep 10, 2009 | Office Equipment & Supplies
Dear Esperts, I want to install HP C7280 on my XP Pro. The pop up message appeared as follow: "Fatal error during installation Invalid Drive: E: Fatal Error MSI.netdevicemanager01 " Any suggestion to solve...
Sounds like a problem with the installation disk.
Try clicking on this link the download the Full feature software and drivers package
Allow it to install. If it works your done, if not the disc isn't the problem. If that is the case respond back here with any error messages that show up and I will take a little deaper look into the problem
Hope this helps Fixya,
Chris
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3204785&lang=en
May 03, 2009 | HP Photosmart C7280 Laser Printer
MSI.dot4wrp01
Fatal Error during Installation - MSI.dot4wrp01
Try this link. I was able to resolve this with this solution.
Mar 25, 2009 | HP Photosmart C4280 All-in-One InkJet...
Fatal Error while install software for HP C8180 printer, Vistax64
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Photosmart 3310 All-In-One - Cannot install..... Downloaded software from HP web site - 96% install it brings up a "FATAL ERROR" message and then uninstalls it. Running Vista - Help
Hi
The installation will get stalled at 96% , because due to 3rd party service running, will not allow to install HP printer driver.To resolved this follow below steps
1.Disconnect the Printer and uninstall the software.
2.Reboot the PC.
3.Click start, then in "start search" box type "msconfig"(without quotes).Click OK.
4.In System Configuration Utility, Under GENERAL tab, click on SELECTIVE STARTUP, Uncheck "Load System Services" and "Load Startup Items".Click on Apply
5.Then Click on SERVICES tab, at the bottom Check "Hide all Microsoft Services" and then click "Disable all".
6.Click apply and OK. Reboot the PC.
7.Now install the software.
Please let me know once you have done this.
Thanks
Rizwan
Dec 09, 2008 | HP Photosmart 3310 Printer
Fatal error message
Hi all,
The error happens if your installation did not finish completely and you didnt have complete access and permission to the system(even though you are an administrator). Run the access denied tool by hp by clicking on the link http://tinyurl.com/5u2pg three times. uninstall the software and reinstall again. If this dosent work you will have to manually change the permissions in the registery.
hope this helps!
cheers
Aug 10, 2008 | HP Photosmart C4280 Aio Printer
113 people viewed this question
k24674
jasbo
jasbo
