Question about Pool & Spa
I have a pure silk Hayward chlorinators that seems to produce NO chlorine. Does anyone know who to talk to or how to fix it?
Plug, Drain on Hayward Chlorinator rusted through and now have a leak
This is a very confusing questions. There are no metal parts on the CL200. Not sure what plug we are talking about.
Aug 28, 2014 | Hayward Pool Products Hayward CL200...
Pipe drain plug in chlorinator will not twist off
drill a pilot hole into plug and remove old plug. worst comes to worst, replace the bloody chlorinator!!!!!
Apr 11, 2014 | Hayward Pool Products Hayward CL200...
Hayward rp30 salt chlorinator
You should get a new one
Feb 25, 2014 | Pool & Spa
24' X 52" intex pool, I am having trouble with my cholinator not producing chlorine in the water. there are no signals or lights flashing. but when I test for the free chlorine on the strips is do
If you can remove your generator try and bench test it. Fill with pool water and do a chlorine test. Run the generator for a few minutes, unit should produce bubbles when the cells are turned on. Run another chlorine test and make sure it is higher than original test. You should also test your combined chlorines to make sure you don't have excess chloramines in the water. Also check for any buildup on the generator plates which should be acid washed, and verify salt concentration.
Apr 01, 2013 | Intex Automatic Salt Water System for ...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
Is a Hayward cl-100 ef chlorinator the right model to use for a 27 foot round above-ground swimming pool. I am having trouble keeping the chlorine level at an adequate level (dips too low) even with the...
The cl100 should do the job. The first thing I would do is check the chemicals. Make sure you have enough stabilizer (cyanuric acid).If it's low your chlorine will not last long at all. Check the ph and alkalinity also. Make sure you are running the pump long enough. the cl100 only adds chlorine when it's running.
Jun 05, 2010 | Hayward Pool Products 25 Sq Ft Micro Clear...
I opened my pool a couple of weeks ago and filled my Hayward CL200 chlorinator with 3'' tablets. I usually set the dial on 2 with good results. After over a week, the chlorine level was nill in the pool....
A CL200 Involves direct injection of chlorine into the pool. Water passes through the chlorinator and goes to the pool with chlorinated. WIth the 200 (Not the 220) I've only seen a handful with problems over the years with chlorine not dissolving. If the chlorinator is not leaking, and the control valve is moving freely here's what I'd recommend.
1. Are you using a new type of tablet?
If so remove the tablets and place into a floating chlorinator.*** WARNING Wear Rubber Gloves, while handling wet tabs****
Dial it all the way open. If the tablets don't break down at this point with in a day or two, They were over compressed at the factory, potentially have to much filler (most slow tablets should be 95-99% cholroine) or the water is too cold ( below 70 deg. This should not be an issue in July) If this is the case switch brands.
If the chlorine is dissolving in the floater but not the chlorinator it could be one of the following.
1. Make sure the direction on the chlorinator is correct inlet (from Filter) to outlet (to pool)
2.. In some of the newer 200 chlorinators there is a built in check valve you can see it in the bottom of the chlorinator You will notice a threaded piece in the bottom that contains a white plastic ball the size of a pea. If this ball does not move freely to the touch, odds are the filler in your chlorine has clogged it from moving, thus preventing the flow of water from dissolving the chlorine.
You can check this by removing the chlorinator from the pool, removing the lid and pouring water directly into the top. If you do not see water passing through to the "Outlet" side of the chlorinator a clog is most likey your problem.
I've seen clogs cleared with wire coat hangers and hot water. Be forewarned that hot water being poured into a chlorinator will cause the any residual chlorine to gas off, make sure you do not have you face over the chlorinator when you add the hot water and you do so in a very well ventilated area. A straightened wire coat hanger can be used to dislodge any obstruction in the check valve and "get the ball rolling again"
Hope it helps.
Jun 10, 2009 | Hayward In Line Chlorinator 9 Lb. Capacity...
Pool & Spa Logo
247 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
