Question about Brett Plummer Android Apps
How to repair a water pipe leak under a concreat slab
Leak under a concreat slab
    Sergeant:
  • 251 Answers
Things to consider are cut and replace -1. Concrete saw the affected area replace and re-concrete (impact hammer is another option but a concrete saw is neater and you can control the cut better.. 2. You can bypass the pipe. 3. Dig under the slab - you obviously would need to be near an edge.
Posted on Jan 18, 2013
Why is their about 15 gallons of water built up under my house within a couple of days, but no visible leaks?
Drain pipes might go under the ground. You have slab leak. Plumber will figure it out, or check blue prints of Your house if You have those(will show You "What Where")
Jan 29, 2015 | Plumbing
Water meter keeps running. When I turn off the water supply to the hot water tank the needle on the water meter stops, does that mean that I have a leak in the hot water pipe coming out of tge tank.
Yes you have a leak on hot pipe or TP overflow tube.
Put ear against pipe to listen for sound of running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
If TP valve goes into drain line, check if water is running down TP overflow tube.
Check each faucet for leaks.
If pipes are under slab, put ear against each faucet to determine which faucet is closest to broken pipe.
Mar 23, 2013 | Water Heaters
My water heater runs constantly lately and i noticed water at my property line and around half my house. i can't tell where the leak is coming from. house is on slab. i am afraid to ask. the floor...
Does the hot-water line running from the heater go into / under the slab before going back into the house?
Or does the pressure relief valve drain line on the water heater go into / under the slab ?
It could be as simple as a faulty pressure relief valve on the heater (which would be the most likely of the two possibilities). When the water heats, the pressure builds in the tank, the water flows out the faulty pressure relief valve and down the drain line under the slab.
A plumber would be the person to call.
Charlie
Feb 19, 2011 | Kitchen Ranges
The bathtub drain pipe [below the tub] is cracked is there any easy fix without removing tub, etc  it maybe could be reached by cutting out part of the adjacent wall otherwise, the water spills onto...
You can do all your fixin underneath where you say it is leaking on the slab if there is room for you to crawl under why remove the tube, more trouble than it is worth.
Jul 18, 2010 | Home
The machine is not making ice. It makes the slab of ice, but it does not drop down onto the cutting grid.
Your unit either has a bad evaporator thermsitor (most likely) which is used to decide when to go into harvest -- or -- it has a refrigeration problem like a hot gas valve leaking past it's seat (less common but often mis-diagnosed)
If you are handy, have a multi-meter and would like futher troubleshooting assistance, write me back and I would be happy to help you. If you want me to recommend a servicer in your area give me your address (or general location).
If the unit makes a half-inch slab in about 25 to 35 minutes, I would wager the thermsitor is bad. If the slab is very uneven or takes a long time to reach one-half inch, I would wager a hot-gas valve issue.
Good-Luck, Subdriver
Mar 31, 2010 | Marvel Appliance Ice Maker
Combi boiler loosing water pressure in heating system no visible leaks i have heating pipes under a concreat floor carpets not damp and no con- densation on my windows the pressure drop is over...
There is a 15mm pipe from the pressure relief valve which should so through to the outside. These valves are prone to leak after time. Look at the end [outside] of this pipe. Wet = leak from valve
Dec 20, 2009 | Water Heaters
Pilot light is on, but no hot water. thermostat is turned all the way up to HOT.
my gas hot water systems pilot light is on but yhe burners dont ignite when i put the hot water on,so in turn im not getting any hot water
Sep 09, 2009 | Rheem Water Heaters
Banging tumbler during spin cycle
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Feb 03, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frozen slabs of ice instead of ice cubes
the icemaker could be leaking by can you see where the water is coming down into the bin from??
Jan 23, 2008 | GALAXY Microsystems 55622
Android Apps Logo
518 people viewed this question
Top Brett Plummer Apps Experts
Brett Duxbury
Brett Duxbury
Are you a Brett Plummer App Expert? Answer questions, earn points and help others
