Question about Gateway Fx Computers & Internet
Cd driver not opening - Fx Gateway Computers & Internet
    Problem Solver:
  • 8 Answers
Open a paper clip and see if you can find a tiny hole in the front of the cd drive. Push the sraightened out paper clip into the hole and the drive should open without power on the computer. The hole on my dvd plyer is just above the switch which opens and closes the dvd drive. If the paper clip is too big you may have to go to a pc shop and buy a pin which comes with most new dvd players. If the owner of the shop is a nice person they may give you a pin and explain more.
Posted on Jan 18, 2013
Y cd driver wont open
just push the button on cd tray... then the tray will open. if won't read then maybe your cd is damage or the cd drive got in trouble unable to read. try restarting your system.
Dec 22, 2012 | HP Compaq nx9420 Notebook
How to boot drivers cd?
why you need to boot drivers cd?/
ok try rhis method
open the my computer
then on the dvd drive right click and click on the autoplay option.
if ther is no auto play option then open the cd then search for setup.exe or search some other .exe files this will run and update your drivers
Jun 15, 2011 | Microsoft Computers & Internet
CD/DVD burner in Compaq Presario 5010NX w/ VistaBasic Reads and any DVD but has problems with CD's. If I load a music CD, sometimes it will open right up and I can play the music. Most times it just...
Microsoft updates may not have the driver you are looking when it is searching for drivers. When you are in the device manager make a quick note to the name of the device and go to http://www.compaq.com/country/cpq_support.html
and see if you can match the device to the driver for your pc. If you are able to find the correct driver and install it and still receive the same results then the drive itself may have a problem.
Mar 14, 2011 | Compaq (CDD480172) CD-RW Burner
My SONY CD-RW CRX320EE reads CDs but it doesnot read dvds correctly and it doest write on Cd when i want to make cd ,it makes it but the cd doesnot open. the dvds donot open but somtimes open. please help...
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 07, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My cd rom drive will not open ive tried the paper clip method and still wont open anything i can do please help
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
if you mean a driver for cd/dvd driver
if your computer came with a disk all the drivers should be on it (motherboard disc)
hope this helps
Jan 06, 2011 | Compaq (120192-B21) CD-ROM Drive
My pc not have sound so i need driver for that
When you have driver cd first it install in your pc and you have not driver cd and you window 7 cd put it into cd drive and open it and go software and open sound folder and install sound driver.
Nov 06, 2010 | AMD Athlon XP 2600+, 2.13 GHz...
I deleted my speakers and soundcard driver by accident, how do i get sound back on my computer?
http://hotfile.com/dl/28511519/c35110f/Open.CD.Drivers.Xp.vista.El_DocToR2.part1.rar.html
http://hotfile.com/dl/28511590/04a0925/Open.CD.Drivers.Xp.vista.El_DocToR2.part2.rar.html
http://hotfile.com/dl/28511631/0fdfc86/Open.CD.Drivers.Xp.vista.El_DocToR2.part3.rar.html
http://hotfile.com/dl/28511693/eccab5f/Open.CD.Drivers.Xp.vista.El_DocToR2.part4.rar.html
http://hotfile.com/dl/28511696/a56a488/Open.CD.Drivers.Xp.vista.El_DocToR2.part5.rar.html
there you go download all these link and then extract, there are 400,000 drivers, trust me your drivers will be in there, kinda of a big file but you didn't specify what your driver. There you go m8
Mar 20, 2010 | Acer Computers & Internet
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
How to print cd covers
ihad cannon 5000. there was same function. fo cd print . we shuld have driver for it .driver comes on with printer. and also come tray to keep cd.. infront of printer ,there is a hole to inserd tray with cd, then we can open this driver .From program. when can open cd write founction there is many design to print cd. thanks
Jun 16, 2009 | Canon PIXMA MX850 Multifunction Printer
Cd rom driver won't open,
There is a pin hole, just below the cd-rom tray where you can use a paper clip to push inside. That will open it.
Jun 10, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
