14inch sony trinitron model kv-14bmr1 mahina ang sound,pero ok ang audio section
jerryg50
  • 1667 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Posted on Jul 12, 2008
ikecur
  • 52 Answers
SOURCE: Sony trinitron KV-27FS100
probably, you have to call for a technician to check for it, the switch of the tv might have some dis alignment of cables
Posted on Oct 30, 2008
SOURCE: Sony Trinitron 2002 model # KV-32HS500
Mine never blinked 7 times but 6, 5, 4 times Yes
Posted on Jan 18, 2009
SOURCE: Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Posted on Jun 01, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Poor sound on JVC LT55N935
Check its speaker first. If found OK, check and replace the damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 04, 2014 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Kv 21gmr1 sony trinitron tv no sounds
Check its speaker first. If found ok, check and replace damaged component/s at its audio output section circuit. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 16, 2013 | Televison & Video
Sony tv black screen
Repairing a TV set is actually a skilled work. If you're not sound in electronics, make sure, that you can't do it; especially to Sony sets. If the set switches ON; with audio output OK, and there is no Video, surely the fault should be with its horizontal scan output section circuit. Check that circuit for fault. To get more details, http://electronicshelponline.blogspot.com/
Nov 22, 2013 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony 32" trinitron perfect picture, but no sound
Check its speaker first. It sounds that the speaker is out. If it is found OK, check for any loose solder terminals at the audio output section circuit, of damaged component/s there.
Sep 15, 2012 | Sony FD Trinitron WEGA KV-27FV300 27" TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
I need circuit diagram of T.V sony WEGA 14inch
Let me know model number of your tv, I can provide you scehamtics for that one.
Thanks.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-20FS120
Do you get sound when you play a dvd thru audio/video inputs?
If this unit has audio output at the back run audio to amp and see if you have audio thru your stereo
Jul 23, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Trinitron KV-32FS13 Popping sound
Loose connections!! (ground areas).ANd audios section!
May 12, 2008 | Televison & Video
Sony trinitron 29 inch kv j29mn
Possibly dry solder joints or faulty coupling capacitors around the audio section.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Picture and sound problem at 21" sony waga color tv
This is due to problem in deflection area and power supply section malfunction. Make one general service by technical person immediately to avoid major transformer failure problem. Since this is initial stage, the cost of repair is probably less.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
