Question about Beko Washing Machines
My washing machine fills up but the drum is not spinning
In the wash or spin cycles the drum does not turn/spin but it pumps or drains the water out.
  •  dean
    dean Jan 18, 2013
    if its a whilpool ,its the lid switch ,%100 i fitted one today
  • calex_riley7
    calex_riley7 Jan 18, 2013
    It is a Beko Washing Machine..
  • Beko Master
  • 744 Answers
Hi calex if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Posted on Feb 14, 2015
    New Friend:
  • 20 Answers
Hi guys.... I have Beko washing machine and it basically started doing the same. Start cycle it fills up, tumbkles a few times then wont progress. It turned out, with mine, it was simply the machine was unable to drain its water. Look at the front, bottom right there should be a flap that pulls open? Behind is a knob/handle that screws in/out. Undo it and water may come out. This is basically the part that cathces any items, such as the kids leaving buttons, toys, earphones and in particular...HAIR CLIPS!!!! What I did was as follows;
Turn it anticlockwise...open it..the knob should pull ot exposing a hole which a pipe/tube comes out of. You may find it full of hair / bits n bobs / hair clips, basically anything thats been in pockets or tumbling around your drum for months!
Get your fingers in and pull it all out (Bit like a plug/drain in your bath full of old hair, yuk) Then screw it back in, machine off then on again. open then shut the door as if starting a new load. You will hear the water fill up. When it gets further on and wants to spin etc, you will hear the water being pumped out of the drum. You should have a hose coming ou the back and directed into your sink drain??
CHECK that hose is not going "uphill" too much as the pump cant get water to go too steeply uphill. Mine also had that problem. Coz of the kitchen unit the drain hose came out the back then up about 45 degrees to go into sink drain.
The waste water will just run back into the machine.
With the hose AND the blocked waste outlet, the cycle will obviously stop running otherwise it will spin at 1000rpm with several gallons of water in it - safety cut off I reckon.
Anyway, after weeks of debating calling someone out, I made the waste hose horizontal or even downhill AND dragged all the gunk out the front flap thingy and its been running perfect ever since.
Posted on Feb 12, 2015
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Motor moduel or a compasttor ,bepends what type machine u got
Posted on Jan 18, 2013
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
  • 36 Answers
SOURCE: does not pump water out or spin after first wash
Dear Customer
Please perform the following
The first thing to check is the lid switch. Open the lid and you'll see a recessed spot that a tab on the lid fits into. Put a screwdriver into the spot, press down and see if you hear a click. If you don't, the switch is bad. That's if you're lucky.
It could also be something as serious as the transmission. Try this: In the search box at the top of the page, type in repair (brand, like ur Whirlpool or anyother etc) washer. A list of sites will come up with a bunch of troubleshooting tips and repair instructions. I used this to fix my washer a couple of weeks ago. Good luck.
Please rate this,Thank u
Posted on Dec 17, 2008
  • 5 Answers
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Posted on May 29, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
barkencoa
  • 3463 Answers
SOURCE: The water will not drain from my drum. The spin
Check the filter, which is located at the bottom front right of washer behind a flap or drop down cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Posted on Jan 28, 2010
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Why won't Affinity fill or spin?
Probably there is water in the drum or the pressure switch is jam in a state of "full of water" or washing machine didn't drain water .. So, the fault should be sought in the elements responsible for control the level (pressure switch, pcb...etc.) or control draining water (drain pump, pcb, filter....etc.).
The precondition that the machine goes into a spin cycle is that pressure switch folded down to position "empty of water".
Dado
Jul 24, 2015 | Frigidaire ATF6000ES Front Load Washer
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Washing machine wont drain keeps bleeping ERR2
Jan 19, 2010 | Haier Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
141 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
