Question about Dowson Video Cameras
Does the 2.5-inch HD Car DVR road dash camera recharge when plugged in to the computer with the usb cable?
There was no AC100-240V power cable with my product. My son told me that the removable battery would charge when hooked into my computer with the USB cable. My cigarette lighter does not work in my car and the only cable included was the DC5V. I have other questions, but that is the most pressing at the moment.
    Problem Solver:
  • 6 Answers
Currently some dash cameras support recharging when connected to a PC, but mostly do not support. Have a look at these dash cameras http://www.szswill.com there should be one suitable for you...
Posted on Oct 22, 2013
SOURCE: Panasonic SDR-H18
You also have to plug it into the power source. They put it together with the charger. Get the charger and you will see that you can plug the AC adaptor cable in the other end. This allows you to power up when you are using the USB.
Posted on Dec 26, 2007
SOURCE: vivitar dvr 550 trouble. Please help
what is a driver
Posted on Jan 06, 2008
SOURCE: Brand new Flip Ultra HD. Giving error "Check Battery Pack Chargin
check the contacts on the bottom of the pack. for some reason, the plastic sheathing covers the positve contact of one of the batteries. i took an xacto knife and cut a small hole to expose that end. after that, voila, no more charging problem. i woke up to a full charge this morning!!!
Posted on Aug 08, 2009
SOURCE: my Insignia HD DV hdmi camcorder wont charge
you must use original wall charger... i have the same one. says in users manual
Posted on Aug 20, 2009
SOURCE: how to import video to mac from HDC-SD20
Just had this problem on my mac with the same camera. Plug everything up as you had before. Iphoto's should open up but you won't see anything. Close Iphoto's and then open Imovies. Click on file and then import from camera. Then follow the instructions. Hope this works for you.
Posted on Dec 30, 2009
Need manual in english hd portable dvr with 2.5"
Hi Cynthia: Not sure what brand name your camera is, but I found this using a simple google search. The picture is the same, but as you must be aware there are several manufacturers along with numerous brands...Hope this helps....Best.....James
Oct 14, 2013 | Mostbuying Portable HD Car Camera DVR with...
How do I download from my Dowson video camera to my computer without all the jerking problems?
have a try with a SD card convertor, take out the TF card and then connect with PC with the convertor, if you still can not read the card, then very probably the SD card get broken, goto http://www.szswill.com to learn more about car dash video cameras...
Jan 21, 2013 | Dowson 2.5 Hd Car Led Ir Vehicle Dvr Road...
How do you recharge camera battery? camera manual is not clear abot how to hook up battery charger or even where it is!
The easiest way is by using a standard USB cable...plug the small end of the USB cable into your camera (located under the headphone jack) then plug the larger end of the USB cable into your PC or laptop. Turn on your computer & this will charge up your Vivitar 550.
Dec 27, 2009 | Vivitar DVR-550 DV Camcorder
I'm trying to plug my sata hd into my esata DVR
What you can do is go to a good computer hardware store like, new egg. or somewhere that sells core hardware for computers. you should be able to buy a PCI-E or a PCI ESata card so you can plug it in. hope this helps!
Sep 10, 2009 | Mag Innovision InnoVision XJ 717 Monitor
Flip Mino HD battery will not recharge
I panicked when I saw all these posts but the reset did work for me. Others say it doesn't but this first time at least, it did the trick. I stuck the end of a paper clip in the little hole in where the tripod mount is (it's further recessed than the mount itself). It doesn't seem like it fits, but it does. The minoHD was off, since by this time it wouldn't turn on. When I tried to turn it on again, it finally came on with the battery in the red zone. I recharged and it appears to be fine.
Jan 15, 2009 | Pure Digital Flip Mino Digital Camera
Vivitar DVR 545 - Is this going to work with my MacBook?
I have a VIvitar DVR 545 I can not find out how to recharge the rechargable battery
I just bought this camera and had the same problem.
How DO you charge the battery???!!!
Here goes:
Open the box the camera came in and you should find a little rectangualr black box and a 3-pin plug.
Ignore the other stuff unless you think you may need it (depends what country you're in and what your mains supply wall socket fittings are). Take a close look at the little rectangualr black box and you'll see a slot in it. That's where your battery goes! Remember the battery must be taken out of the camera and slotted into this box! Make sure you align the battery correctly to the litle pins inside the box.
The Vivitar DVR 545 uses a sort of mobile phone/cell phone battery.You must take the battery OUT of the camera. Now you have slotted the battery into the box you connect the 3-pin plug to the box and then insert the plug (attached to the box) into your wall mains supply socket. The box will light up and you'll see a red light. Once this light turns green your camera battery is charged!
RE-INSERT THE BATTERY INTO THE CAMERA.
The whole charging procedure for the DVR 545 is ridiculous but there it is! By the way one drawback about having to remove the battery from the camera to charge it is that you will lose all or most of your camera settings. remember to reset video and photo settings - resolution, flash etc., etc.
Also a word of caution:
The Vivitar DVR 550 is unusual in that the battery is charged using the USB port. If you also happen to have a DVR 550 do NOT attempt to charge the Vivitar 545 using the Vivitar DVR 550 USB charger cable!
You will destroy your DVR 545 in seconds!!!!
Jul 09, 2008 | Cameras
How to connect a IDE-to-USB cable to a 2.5 inch drive?
1) You will do no harm by reversing the connector, but the PC won't "see" the drive at that point (if your drive has an activity LED it will be permanently ON if the cable is reversed) 2) Most times the USB will have enough power to drive the HD all by itself, but if you are going through a hub that may not be the case. In that situation, plug the device directly into a USB port on the PC.
Apr 22, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Video Cameras Logo
75 people viewed this question
Top Dowson Video Cameras Experts
Steven's...
Steven's...
Tony Parsons
Tony Parsons
Are you a Dowson Video Camera Expert? Answer questions, earn points and help others
