Question about Bosch Nexxt WTMC3321US Electric Dryer
Dryer turns, heats up but won't dry
Dryer will run for selected time. It turns, it heats up but won't dry properly. There seems to be blow back of lint which suggests vent line is plugged. I pulled everything apart and cleaned all vent line to outdoors. vacuumed vent line from back of dryer in as far as hose would go. I pulled collected lint from down in the deep crevice below the lint filter and vacuumed everything thoroughly.
I ran dryer without vent tube attached to check for air flow. Very strong flow with hot air coming out of the back vent ( stronger than before all the cleaning).
I figured that all the cleaning solved the problem, so ran a wet load on the 40 minute cycle. Cloths were warm and still very wet and still appeared to be lint blow back as though the vent line is still clogged. I then ran the dryer on regular setting and after 30 minutes or so the cloths were dry. Filter did not have a "tight" pack of lint as when dryer was working normally.
There appears to be some sort of trap door or compartment that is out of reach from any part of a dryer opening that is not allowing the air to flow through.
Any help or advice will be appreciated.
  • sgtslayton Feb 25, 2009
    Thanks for the suggestion - that was the first thing I tried. Everything is clear from the front of the dryer to every inch of exhaust. My real problem now is getting service from Lowes where we bought the machine. Called the sercie number on our extended warrenty card and Lowes gave me 2 numbers to call myself to set up an appointment. Called the 2 companies and neither of them do service for Lowes. So it's getting more complicated all the time !
  • sgtslayton Mar 07, 2009
    Many thanks for trying to help. Since lowes couldn't find anyone in our area to service the unit ( under warrantry ) - they actually came through for us and exchanged the dryer for a new one of the same model. So now maybe we can get 2 years out of this.
    We'll never by another Bosch again for sure.
    Thanks again for trying to help...........
  • 686 Answers
Check the outside of your house to see how strong the blowing is if it's weak then it's in the vent tube
Posted on Feb 18, 2009
  • James Chandler Feb 27, 2009
    check your heating element/s there may be a double element and one might be bad. try that ok! Good Luck
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
My electric amana dryer heats up but does not seem to blow the heat around and the lint is only gathering at the bottom of the lint trap, so it takes forever to dry my clothes. What do I need to do?
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Amana ALE230RAW Electric Dryer
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
The heating element in my Kenmore dryer, model number 110.63032101, does not fully heat up sometimes. With the setting on cotton/high the element will sometimes be fully illuminated and sometimes only...
no,that's how they run,if your clothes are drying and the dryer is cycling on and off,leave it alone,if the clothes are taking a long time to dry clean out the duct that the lint filter slides into and blow out the vent line with a leaf blower if it's a long run
Oct 12, 2010 | Kenmore Dryers
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
Dryer continues to run but heat fuse blows when turned on.
You would need to check the amp draw to determine if it is the dryer or your house circuit. A dryer typically draws a steady 24 amps when it is heating.
Apr 07, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Bosch Nexxt WTMC3321US Electric Dryer Logo
326 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
