Question about Deeluxe 2012 Spark Snowboard Boot -
Lacing system repair
Lacing cleat broke off
Unscramble letters to create a word. letters: scsgtlaae
Alga Sects
Gala Sects
Galas Sect
Cage Slats
Cage Lasts
Cage Salts
Glaces Sat
Cages Last
Cages Salt
Cages Slat
Lace Stags
Scale Stag
Scale Tags
Laces Stag
Laces Tags
Scales Tag
Eclats Sag
Eclats Gas
Cleats Sag
Cleats Gas
Castle Sag
Castle Gas
Eclat Sags
Cleat Sags
Castes Gal
Castes Lag
Caste Slag
Caste Gals
Caste Lags
Lac Sagest
Lac Stages
Lacs Stage
Lacs Gates
Class Gate
Talcs Sage
Talcs Ages
Talc Gases
Talc Sages
Casts Gale
Scats Gale
Acts Gales
Scat Gales
Cast Gales
Cats Gales
A Lacs Gets
A Class Get
A Sacs Gelt
A Casts Leg
A Casts Gel
A Scats Leg
A Scats Gel
A Acts Legs
A Acts Gels
A Scat Legs
A Scat Gels
A Cast Legs
A Cast Gels
A Cats Legs
A Cats Gels
A Gal Sects
A Lag Sects
A Slag Sect
A Gals Sect
A Lags Sect
Lac Sag Set
Lac Gas Set
Lac As Gets
Lacs As Get
Sac Gal Set
Sac Lag Set
Sac Sag Let
Sac Gas Let
Sac Stag El
Sac Tags El
Sac La Gets
Sac Las Get
Sac As Gelt
Sac Sat Leg
Sac Sat Gel
Sac At Legs
Sac At Gels
Sacs Tag El
Sacs La Get
Sacs At Leg
Sacs At Gel
Acts Sag El
Acts Gas El
Acts As Leg
Acts As Gel
Scat Sag El
Scat Gas El
Scat As Leg
Scat As Gel
Cast Sag El
Cast Gas El
Cast As Leg
Cast As Gel
Cats Sag El
Cats Gas El
Cats As Leg
Cats As Gel
Cat Sags El
Cat As Legs
Cat As Gels
Act Sags El
Act As Legs
Act As Gels
Gal As Sect
Gal Sat Sec
Gal At Secs
Lag As Sect
Lag Sat Sec
Lag At Secs
Slag At Sec
Gals At Sec
Lags At Sec
Sag La Sect
Gas La Sect
Stag La Sec
Tags La Sec
Tag La Secs
Tag Las Sec
Oct 27, 2016 | Computers & Internet
Rapid lace system problems.. uneven lace
Hi All,
I had an uneven problem with the DC Siloh '09s. Not sure if it will cover all makes and models but I will explain how I fixed it.
Key for the instructions:
Numbering the laces from top to bottom 1-8, outer side of the boot = little toe, innerside = big toe, and on the two laces that lock on either side of the boot (4 in total) toe and heel lace.
1. In order to make the laces even again you need to unlock the heelside lace on the outerside of your boot, this lace controls lace 3.
2. Pull lace 3 using creating slack now that it is unlocked
3. Pull the slack through lace 4 and then 5.
4. Once you have slack in lace 5 unlock the toe side lace on the inner side of your boot.
5. Holding that same lace pull the slack through the locking mechanism until you are happy with the balance.
For moving slackness from the inner to the outerside the opposite approach applies.
If it is not clear, reply and I'll try and take a photo or post a video or something.
Cheers
Mikey
Aug 12, 2012 | DC Shoes DC Methvin Snowboard Boot Men
The patent leather on my laces are coming off took them to a shoe repair he said nothing he can do help I want to wear my shoes
Theres the obvious which is get new shoes because they do still make them, but there are other solutions. One you can wear the laces as they are. Two you can look online to find new laces, but they are extremely hard to find. Three look for laces that are similar but can replace the laces. Four buy a used pair just for the laces. Now all of these will only work if they laces can come off. If not then there is nothing you can really do to fix the laces the way they were unfortunately.
Jun 03, 2011 | Rocawear Sofi Sandals for Women
I have a central pheumatic stapler model 99640. When I used it, it shot out 2 'L' shape cleat (16G, 2") at the same time instead of 1 cleat. I tried to minimize the gap for the mouth, it end up jamed....
I have noticed that some nailers with this problem have a driver blade that is slightly wider than the width of the cleat thus allowing the driver to actually hit part of the second cleat in the strip. To fix problem the driver blade should be slightly trimmed or tapered. File/grind the driver only on the side facing the cleats. Remove only enough metal to allow driver to hit only one cleat. Taper the grind up about 1/2 inch. This tapering is used on many different drivers including fraiming nailers to prevent the driver from hitting second nail on strip (mainly clip head nails). Only other remedy is to find thicker guage cleats that will still fit thru nose. Good luck with your repair
Oct 08, 2010 | Craftsman Air Tools & Compressors
I have a pair of DC Siloh boots that are a couple years old, and I'm having some trouble with the rapid lace system. The lace on the inside of the leg, which tightens the lower half of the boot, will not...
I have exactly the same problem. I just wounder if you managed to solve it yet? I don't know what to do, but every time I try to put them on I have to struggle for about 20 min! It gets so annoying!
Mar 05, 2010 | DC Shoes DC Siloh Snowboard Boot - Women's
I am unable to loosen the laces on the exterior of the boot. Only the bottom half is loose and the top three laces remain very tight.....as if there is a knot inside the boot lining.
Sometimes if the boots have been well worn the lace will pill inside its tubing and become stuck. The best way to fix this is to untie the jammed lace at the bottom and then pull from the top to remove the damaged lace. You will also need to get a replacement lace from your Burton store to repair in reverse.
Feb 11, 2010 | Burton Moto Men's Snowboard Boots '09
I ran over a shoe lace and now it is making a loud rattling noise
The All Floors model has a protective belt clutch system and the rattling sound means the clutch has slipped. This would have to be repaired officially by a Dyson repairer.
Jun 15, 2009 | Dyson DC07 All Floors Bagless Upright...
Deeluxe 2012 Spark Snowboard Boot - Logo
85 people viewed this question
Top Deeluxe Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Deeluxe Winter Sport Expert? Answer questions, earn points and help others
