Question about Asko 1385 Dishwasher
A raindrop on time display - Asko 1385 Dishwasher
Raindrop light is blinking and printer will not print.
???? RAINDROP do you think perhaps that means INK supply is low .
Sep 30, 2015 | HP Deskjet 5650 Workgroup Color Inkjet...
Goodman wall unit air conditioner WMC 24-1A has a orange raindrop light displaying and is leaking wayer from the right side???
You need to make sure the condensate pump is working. Check the voltage and the float in the sump.
Jul 21, 2014 | Heating & Cooling
Electric fireplace
Is it that soud stay for long time, let say 10 minutes?
It can be some piece of metal moving when fireplace heats up.
If this fireplace has fan installed, small lousy bit of metal can play.
Nov 13, 2013 | Heating & Cooling
Why is it the rain drops cannot kill people?
Raindrops have a small volume and low mass, so they reach terminal velocity very quickly - they stop accelerating long before they reach a dangerous speed.
I hope this answer helps!
Aug 01, 2011 | Health & Beauty
Raindrop symbol flashing - won't print
Try replacing the cartridges, if that doesn't fix it then that means the printhead is bad and since you can't buy that part, you would need to get a new printer.
Nov 03, 2010 | HP Deskjet 6940 InkJet Printer
It sounds like raindrops inside my window ac
when the humidity is high it condenses on the evaporator .. that water runs out of a drain if the unit is properly mounted . a little of the water is retained and is used to help cool the condenser coil ... thats the sound you hear .. water is being picked up by the fan and splashed over the condenser coil to help increase the efficiency of the unit ... if the unit is mounted such that its tilted in a little then you may get too much retained water ... the same if the drain is clogged .. but a little water splashing around is normal and a desirable thing to increase efficiency ... check the mounting angle and the outside condensate drain,,
Jul 25, 2010 | LG Electronic Window Air Conditioner
Are all symbols on a/c the same
Ok the snowflake means that the unit is cooling. The sun means that the unit is heating, the raindrop means that the unit is dehumidifying, the fan means that the unit is using the fan only as ventilation without cooling or heating and the funny triangle looking thing is auto mode where the unit sets the mode automatically. The little bar in the middle displays fan speed and the two little arrow things next to it means that the fan is in auto mode where it sets the speed automatically. There I hope that that helps.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 25, 2009 | Heating & Cooling
Cant feel heat using remote 6711A10010D
You need to ensure that the LCD displays a sun symbol. If this is not the case this can be corrected by using the button which has triangle, snowflake, sun and raindrop symbol, press until sun is on screen. Then set temperature.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 08, 2009 | LG LSC121PMA Split System Air Conditioner
Asko 1385 Dishwasher Logo
44 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
