Question about HEWLETT-PACKARD HP Pavilion G71150us Notebook
Hp g7-1150us will not power up - HEWLETT-PACKARD HP Pavilion G71150us Notebook
  • HEWLETT-PACKARD Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Jan 18, 2013
Hp C7280 will not power up
Sir/Madam
It's Seem That Your HP Printer Power cord Is not Connected Properly,so I strongly suggest You Check Your Check Your Power Cord Is Connected Or Not If yes then May be Your switch is Not working Correct Or If No Then
Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Reinsert the cartridges, and then close any open doors on the product.
If you receive a prompt to print a calibration page, do so.
Reconnect the USB cable to the rear of the product, and then try printing again.
Hope Your Power For HP Printer Solved By Now,If No Then Go To Below Link URL:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02036357
I Hope Your Power For HP Printer Solved By Now After Click On Official HP Printer URL Link,
In Case You Still Have Problem Then Follow US On For
HP Printer Support
Jan 08, 2014 | HP Photosmart C7280 Printer
My HP Diskjet F4180 All-in-One is working right
Hi
Please remove the power jack of the printer from the power surge and when required you can connect it and use it. It will also saves power and the cartridges will not dry due to power.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00853006&cc=us&lc=en&dlc=en&product=3177566
Jan 14, 2010 | HP DeskJet F4180 Inkjet Color All-In-One...
HP PSC 1410 All in one printer
Reset the HP All-in-OneFollow the steps below to reset the All-in-One.
  1. Turn off the HP All-in-One by pressing the Power or On/Resume button.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the Power or On/Resume button.
Nov 30, 2009 | HP PSC 1410v All-in-One Printer
Laptop won't power up without battery, needs 135W adapter
The ASUS power adapter is below spec and it may damage the adapter because the HP is drawing 45 W more power than it can deliver and will cause it to overheat.
The 17" HP requires 18.5 or 19 volts depending upon the model of the HP laptop (check the power requirements on the label on the bottom of the laptop). If the ASUS adapter doesn't deliver this voltage, it most likely won't power up the HP laptop.
Use the power supply/adapter from the other 15" HP. If this HP's adapter has a voltage output of 19 volts and the 17" laptop requires 18.5 volts, don't worry a voltage difference of 0.5 volts, the only problem is whether the power plug will fit into the power socket of the 17" HP laptop.
Oct 28, 2009 | HP Pavilion zd7020US Notebook
My hp officejet 7410 all in one display only hp invent and not respond
Perform a power reset
  1. Press the On button to turn off the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
Sep 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
6210 Stuck in self test mode
Perform the steps provided below.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
AFTER PERFORMING THE STEPS IF THE ISSUE PERSIST FOLLOW THE STEPS PROVIDED BELOW.
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Hope you like my info
May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp c7280 all-in-one printer will not shut off
I'm assuming your printer power button will not shut the printer off. You can unplug the power connector from behind the printer if it won't shut off via the power button or power switch.
Performing a power reset
Apr 20, 2008 | Office Equipment & Supplies
HEWLETT-PACKARD HP Pavilion G71150us Notebook Logo
327 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
