Question about Hyundai Vehicle Parts & Accessories
My accent car's clutch pedal becomes loose at every time running i have changed clutch plate and adjusted the pedal but still it shows problem
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 47 Answers
Did you bleed the air out it's just like the brake sys it has a bleed valve to get the air out
Posted on May 17, 2013
How to adjust the clutch on a 1999 Ford escort ZX2
The clutch is not adjustable it is fully hydraulic. That means it is self adjusting, if the clutch pedal engages high on the pedal and the clutch is hard to push you need a new clutch plate and pressure plate.
Mar 18, 2017 | 1999 Ford Escort
When i press the clutch pedal down it makes a rubbing noise similar to worn brake pads.stuart
opel vectra ,,,,ot sure if their is a automatic adjustment on the pedal ,if so it could be this failing which the cable could be frayed ,would really need to see it to know for sure
Feb 08, 2016 | Opel Vectra Cars & Trucks
91 mazda navajo with 5 speed manual transmission get's really hard to shift gears after driving 20 minutes or so, also will not go into any gears (like it's locked up) sometimes when I park and I will
Hi Donna:
If you try filling your clutch resavoir with brake fluid, its probably low level? If this is OK, then sound like clutch plate or clutch adjustment seems to be the most likely thing in that it is not disengaging fully. Check the adjustment.
Other problem could be worn gear linkages and joint bushes, I suggest check check play along gear change train from gear lever to gearbox selector input.
Finally, you might have an internal problem with the clutch or the transmission itself, although most manual transmissions are hydraulic, meaning they require fluid to operate. The clutch master cylinder is usually next to the brake master cylinder.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 16, 2011 | 1991 Mazda Navajo
Can you adjust the clutch on a 2002 hyundai accent
The clutch in this car is a hydraulic design and is self adjusting. If you have a hard pedal with high pedal engagement or a slipping condition you are going to need a new clutch installed.
Oct 28, 2011 | 2002 Hyundai Accent
How to change clutch lining on saturn 99 manual transmission
you dont normally change clutch lining .. you replace the "clutch plate" .. that includes lining .. you have to remove the transmission to get at the clutch plate .. if your clutch is just slipping (not chattering) then that could be just the clutch "free pedal" adjustment ... you should have some free movement of the clutch pedal before it engages the clutch .. maybe an inch or two .. you should feel resistance only after you move the pedal that far .. if there is no free pedal then it may be keeping the clutch from fully engaging .. the free pedal adjustment is usually easy to do and not expensive ..
Feb 22, 2010 | 1999 Saturn SL
1998 Hyundai Accent clutch pedal travel
dear friend-you can bleed the clutch.im am sure this will solve you problem
Jun 30, 2009 | Hyundai Motor 1998 Accent
2002 Sunfire
check automatic adjuster on clutch pedal under dash .
May 08, 2009 | 1997 Pontiac Sunfire
To change gears, I need to fully press down on my clutch pedal to stop a grinding noise on my hyundai accent 2001Can I adjust the clutch cable,
Hi and welcome to FixYa,
In a manual 2001 Hyundai Accent, the clutch cable could be adjusted. The adjustment point is on the cable 'pad' where it enters the firewall in the engine compartment.
To adjust, the slack or free play must be decreased. This is done by turning the adjusting nut clockwise. Check back by pressing on the clutch pedal to your preference.
Good luck and thank you for using FixYa.
Feb 18, 2009 | Hyundai Motor 1995 Accent
Clutch pedal low near floor, can the clutch be adjusted?
hi the clutch on accent is hydraulic operation so if pedal is very low on disengaging clutch ? you may have a problem with the hydraulics 1st thing to check is fluid level? this is the reservoir that feeds both brakes and clutch but is seperaterated inside if fluid low? top up and bleed the slave cyl however if fluid low indicates a leak ? possibly slave cyl? if no loss of fluid ? then prob may be fault in the master cyl ? check fluid come back with any update please ps if this problem has just occured? check for leaks ?
Feb 02, 2009 | 2005 Hyundai Accent
HOW TO KNOW WHEN SHALL I CHANGE CLUTCH DESK?
To reduce clutch disc/plate problems, avoid riding the clutch whilst driving, ie having ur foot on the clutch pedal when the engine is in operation, especially wqhen the vehicle is in motion. You see the clutch disc is sandwiched between the flywheel of the engine & the pressure plate. When the driver presses the clutch pedal, the sandwiching of the clutch plate is released, so therefore no drive is being transmitted from the engine to the road wheels. This gives an effect as if the vehicle is in neutral (engine can be revved, with no movement or propulsion of the vehicle). When the driver releases the clutch pedal, the clutch disc is now sandwiched tightly causing the drive to be transmitted to the road wheels which will now cause the vehicle to be propelled.
Clutch discs are only replaced when there are problemes with clutching in and changing gears. After constant pressing of the clutch, the asbestos material on the clutch disc after a period grinds down (clutch disc becomes thinner), which in turn will reduce friction characteristics when all the elements are sandwiched. This causes a slipping effect, preventing the drive from being transmitted to the road wheels efficiently. This causes other problems such as high fuel consumption, erratic engaging of gears, hard selecttion of gears, heavy vibration of the vehicle, stalling; just to name a few. In most cases an unusual smell of the clutch disc is observed.
Also just by resting ur foot on the clutch pedal while engine is running can be dmagaing too. You see the clutch release bearing rests on the pressure plate, so when the clutch pedal is pressed by the driver, there is a degree of friction being placed on the bearing because the pressure plate is always rotating with the engine. The clutch release bearing is stationery until the clutch pedal is pressed by the driver, which sends it into the moving pressure plate, so less pressing on the clutch pedal the less friction between the bearing and the pressure plate. Only operate/press/place foot on the clutch when necessary
Dec 30, 2008 | Hyundai Motor 1995 Accent
Vehicle Parts & Accessories Logo
61 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
