Question about Dell Latitude D800 Notebook
Charging System does not work and Lines on LCD
My laptop D800 does not charge the battery, I have also checked the status of battery by placing it in some other same laptop. Battery is perfectly OK and give working time approx 2hours and 40 min.
Moreover, i have got some lines on my LCD. There is no problem with VGA card because once I get it connected with other monitor it gives display without lines. I will be highly obliged if you tell me the sloution of these problems
  • 3 Answers
I have a dell 9300 that had vertical lines.
I wrote to Dell and said my wife, my sister, my daughter and myself had trouble with the laptop screens. They did not reply but sent me a box with return mailing instructions. Without a word either way, my laptop was fixed. There is no question in my mind there are shorting problems under the case. On three of my dell laptops I need to use a cord to plug in. THE BATTERIES have some sort of connection problem. If I touch the bottom part of the case(while entering data, it oftentimes moves the mouse or the mouse starts dancing. I have to work without the battery. I read where some fellow opened the case gently and inserted a hard piece of thin clear plastic to separate the case somewhat from the guts, so to speak. That may be some help. All of my laptops are kept open now while I can. It seems the back where the lid goes down is fragile. On two of my laptops, the usb ports moves about like a broken arm.The internal architecture is great on a dell. They might use tin cans to make the outside. I wish they would use a solid plastic.
If you can try a docking station that might help. I do not think you can do anything else other than see if there is an open line from where your batter plugs in up to the motherboard.
Posted on Jan 25, 2009
ACER 5810T LAPTOP BATTERY NOT CHARGE IT SHOW THE MESSAGE "PLUGGED IN ,NOT CHARGING"
If your laptop computer runs normally on your acer 5810t charger, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
Jan 29, 2013 | Acer Aspire 5810T-8060 Notebook
Acer aspire zg5 battery not charging
If your laptop computer runs normally on your acer aspire one zg5 ac adapter, but the battery won't charge, please try the following troubleshooting steps:
Jan 09, 2013 | Computers & Internet
Laptop Battery Problem
If your laptop computer runs normally on the ac adapter, but the battery won't charge, please try the following troubleshooting steps:
Dec 07, 2012 | Lenovo Computers & Internet
My dell inspiron 6400 won't start, red light then green light flashes ansd nothing happens, try to take out the battery and putting it back, no results, help
The following troubleshooting guidelines are basic troubleshooting steps. Battery Charging It is recommended to charge the battery while the system is off for faster charge times. Users may notice longer charge times when the system is powered on and running graphics extensive applications.
No POST If the system does not perform a Power On Self Test, there are various things to look for:
  1. Check to ensure that the system has a power light.
  2. If the system has no power light, ensure that it is plugged into AC power. Remove the battery.
  3. If the system has power but is not performing a POST, check to see if the keyboard status lights flash to indicate a successful POST, but no video, or that the keyboard status lights are lit in a sequence indicating a system problem.
  1. With the power off and the system unplugged, remove all CRUs from the system and reconnect that AC adapter to the system and try again.
  2. Run the On Board Diagnostics (OBD).
Video If the LCD on the system shows no display, or has other LCD problems, there are some basic steps to take:
  1. If the LCD is not displaying video or the video is garbled, run the BIST Test.
  2. If the LCD is not displaying any video, connect an external monitor to eliminate a no POST problem. A good image on the external monitor eliminates a video card problem or a POST problem.
  3. Connect an external monitor when possible for all LCD related problems, to help eliminate a software possibility or video card problem.
  4. If the LCD has extremely dim video, attempt to adjust the brightness or connect an AC adapter to eliminate a power management conservation setting set in the BIOS.
  5. If the LCD has lines on the screen, check the system during POST as well as system setup to verify if the lines are present in all modes of operation. Run the BIST Utility.
  6. If the LCD has color problems, run the BIST Utility.
  7. Run the On Board Diagnostics (OBD).
Jul 19, 2011 | Dell Inspiron 6400 Notebook
I noticed that my charging status of my M-2623u laptop shows a "Plugged in, not charging" status. I turned off the system, took out the battery, waited 5 minutes, reinstalled the battery, and...
Similar topic on answers.microsoft.com below, may it would hlep:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Apr 25, 2011 | Gateway M2623u Laptop Charger...
How. do you check if battery is okay.Is there a
the laptop battery is charged with an advance system to regulate the batterry life. To check your battery for optimum performance it is important to charge the battery at least once a week after the charge had gone down to less than 10 %. this will not allow the cells to develop reverse polarity making it drop in efficiency.
Now in the control panel you can open up the icon Power, you will find the status of the battery orr if charging the status of the charging. the icon can be alos found on the lower instant toolbar. the percentage of the charge on battery or charging percentage will be indicated when you place the cursor near to it. make sure that you fully charge the battery always and not to mid charge or run it too low all the time.the time you get for the battery to power your laptop will determine the efficiency of the battery.By these methods you will get good performance of your laptop battery. Helpful advice? good day
Jul 12, 2010 | Acer Aspire One PC Notebook
Hi! my dell d800 wont turn on. I have take then battery out and such and then put it back in but it still wont work. I have put the charger into the computer and the computer says its not charging the...
the battery is damaged..replace the battery with a new one or you will have to run your laptop straight from a eletric power source with the battery removed.
May 02, 2010 | Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
Battery is not charging properly ....?
Have you checked the bios battery status and bios version? first check if battery has charge if yes then update the bios. also try to remove batt and use ac adapter alone and check if laptop has sufficient power. try connecting ac adapter to a diff wall socket. if laptop works fine with ac adapter alone then batt might has problem.
Sep 28, 2009 | Dell Latitude D620 Notebook
Battery not charging...but is recognized by V2000
My guess since the battery checked fine in another laptop would indeed be the charging board or charging circuit on the motherboard.
Jun 14, 2008 | HP Compaq Presario V2000 Notebook
Dell Latitude D800 Notebook Logo
93 people viewed this question
Alun Cox
