Question about Samsung Computers & Internet
When I put on my computer the screen is dim and my auto reset button is not able to fix this.. please help
  • Samsung Master
  • 2,385 Answers
Increase the bightness using function buttons of your system
Posted on Jan 18, 2013
IPad air suddenly went black, except for a dim rotating circle of dots in the center of the screen. It is completely unresponsive. Know any fix we could do?
Put it on to charge. Press and hold the On button and the Home button until the white Apple logo appears and then let go. This is called a Soft Reset.
Dec 11, 2016 | Tablets & eReaders
Dell vostro screen dims and goes off
Yes it is possible for the inverter to be bad. I would watch on eBay for an inverter that has been tested as good or is brand new. They are usually under $10.00 and may be all that is needed. You can also remove the bezel and make sure that the connector from the computer to the inverter is in there solidly and didn't jostle loose. That is also an easy fix. If either of those do not fix it, let me know and I can help further.
Dec 18, 2011 | Apple iMac Computers & Internet
Laptop screen dim - impossible to see display - computer starts up normally.
there should be a row of buttons up near the base of the screen. you have to go to the screen menu and you need to reset it to the main settings. if that don't work then you need to go to the control panle and reset the settings in the apperence section.
Dec 09, 2010 | Fujitsu Siemens Computers & Internet
Auto adjust problem on dell monitor.
I can tell you it was most likely caused by the movement of the machine instead of the memory chip. I would suggest doing a few things, first unplug the monitor from the computer, then power on and through the menu in the screen hit "Factory reset" then power off, from there plug it back into your machine and tighten the screws until they are tight - hey I'm guilty of the sloppy plug myself but it will eliminate the need to check it later. Now reboot the computer with the monitor on. Hope this helps.
Apr 01, 2009 | Dell Computers & Internet
Frozen Completely
Press and hold the 'user' button with the play/on/off button. This should reset the player.
Aug 25, 2008 | Samsung YP-U3 MP3 Player
Power Brightness dims after using Kinoma Player
Ok i think i can help,
Step 1: Go to preferences
Step 2: Go to power
Step 3: Change the Auto-off after: feature and increase it to 3 minutes, the maximum.
I know this will only help it a lil from the 1 minute you had before, but if you pres the volume button or something within the 3 minutes it will restart the 3 minutes.
Masalama
Sheeraz Khan
Jan 02, 2008 | Palm Treo 755p Smartphone
The bottom of the screen has become darker!
Hi
The symptom you are telling is similar to FL inverter problem but with that case usually entire screen goes dim. You may try to reset the settings (Usually AUTO button). Unplug and plug in the electrical connection+Computer connection. Also make sure your Display setting in computer side has not been modified. If issue persist take to the qualified service center. FL inverter is the illuminator part of LCD works like fluorescent tube. FL inverter issue rather lower cost compare to other LCD issues.
Good Luck Happy New Year
Dec 28, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Auto-off not working
I heard this happens after updating the Treo 650 with the new version 1.17. Is this your case? If so just remove the new update... Anyway, you can try the soft restart or even Performing a system reset(from the user guide p.170): ".. Performing a soft reset A soft reset is similar to restarting a computer. If your Treo is not responding or you have trouble synchronizing with your computer, a soft reset may help. 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. Use the stylus tip to gently press the reset button on the back of your Treo. .."
Jan 03, 2006 | Palm Treo 650 Handheld
Computers & Internet Logo
14 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
