Question about Epson Stylus C46 InkJet Printer
My printer is saying the cd tray isnt closing but it is closing and theres flashing red lights all the time
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi Lorna
    Presumably this is your R220 printer problem previously reported in the C46 section, and,yes, you have STILL reported it in the C46 section. The R220 experts/ wizzes may well not see it in here. Do it again in the R220 section.
  • Sanath Kumar V May 11, 2010
    Model# and Brand Name of the Printer
  • Epson Master
  • 541 Answers
If you go to
download the software and it will reset your printers
Posted on Mar 08, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Printer will not print
This normally occurs when the CD tray is open. close it and try again.
Apr 20, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson R260. Brand new. Green light blinks, red stays on. says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
Red flashing lights and it sayin the cd tray isnt closing
It looks like lornapowell1 has lost interest in this problem, so I think we can call it "solved by poster"
Jan 25, 2009 | Epson Stylus C46 InkJet Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
I have a problem on an EpsonStylus Photo R200-when I turn it on the green 'on' light turns off after a couple of seconds and the two red lights will flash on and off alternately. I have disconnected from...
According to the manual:
"The CD/DVD tray guide has been left open when you turned on the printer or when printing on paper. Close the CD/DVD tray guide."
Hope this helps
Oct 14, 2008 | Office Equipment & Supplies
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Cd tray not feeding
I had the same problem. My printer was sitting too far back in the cabinet and the cd tray was hitting the back wall when it was pulling it throuh. I moved the printer forward and the obstruction in the back was no longer an issue. It started printing all cd's just fine.
Jul 17, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
