Question about Chauvet Cirrus Led Laser Dj Club Dance Effect Light
I need to replace my chauvet cirrus power cord
The power supply is 5 VDC, 3 A, 15W 0.2A Max. I Can't find the part listed on their website. Can I just order a 3rd party manufactured power cord and use that? Will it fit in the plug hole?
3 Suggested Answers
PolyrhythmFX
  • 109 Answers
SOURCE: WHAT TYPE OF POWER CORD OR POWER PACK WILL I NEED
If the power connector on the back is a 3-pin socket then get a standard IEC power cable. If it is a small rounded socket then get the corresponding power supply. The unit pr user manual should give the correct specs on the required voltage, polarity, current consumption, etc.
Posted on Oct 02, 2009
  • 5603 Answers
SOURCE: Looking for a heating coil
Use high air pressure after soaking the element. This means the pressure from an air compressor not the little canned air things. You might do this while element is hot... use EYE protection while doing it!
Posted on Sep 08, 2011
Intimidator light wont come on
I have 6 of these in my lighting rig, and the most common problem has been a bad bulb socket. If your bulbs end up with corroded or blackened terminals, you should replace the socket. The black/corroded stuff can cause the connection to become intermittent, sometimes so badly it entirely doesn't work.
The other common problem I've seen involves a resistor on the circuit board that powers the light bulb. I believe it's R2 - regardless it's the only big one. It's value is .5 ohms at 3 watts. Be sure to use a flameproof resistor when replacing it, and most likely your fixture will light up again.
Dec 20, 2011 | Chauvet Intimidator 1.0 Dmx-600 512...
Peavey vk100. v3 filament burns out when amp is turned on
V1, V2 and V3 heaters are in parallel and they are fed through the 6L6 heaters that are in series from the 30V DC HTR supply. If V2, V1 or neither are plugged in there is over current to the heaters and therefore over voltage to damage V3.
Aug 11, 2017 | Peavey Valveking Vk100 Guitar Head
Light is dead all fuses are good.. Maybe bad transformer ?
Probably NOT the transformer as most of these have switching type supplies. A Chauvet unit I have would not light and the problem was the socket for the Halogen bulb. The socket had burned and the contacts were so burned they would not contact the bulb. Worse, you can't even see the problem as the socket is ceramic and has a mica like cover. Replacement of the socket fixed the problem. In the Chauvet unit they had a very cleaver lamp power supply. That threw me off because there was no voltage at the socket... until I put the Oscilloscope on it... then there were tiny spikes. It turns out the supply sends tiny spikes out and IF the lamp is there and contacts are good, the supply senses the load and the feedback starts driving the supply to full output. I wasn't able to see the burned contact until I uncapped the socket. Just maybe you have a similar problem. These 250 watt Halogens with the tiny pins carring 11 amps just are ******* the contacts in the sockets.
Aug 05, 2011 | American DJ Supply American DJ Accu Scan...
Hello, i bought a ledrain 36 about 3 yrs ago the fuse just keeps blowing every time i replace it could you please give me some idea what the problem could be because non of the pcb looks burnt...
The power supply has likely failed. Schematics are hard to find and working on these takes some skill. The supply is a switching type and usually the main switching transistor and sometimes the driver and the regulator chip fail. There OFTEN is NO visiblke evidence of the failure. To avoid blowing fuses use a 40 watt lamp in series with the power cord. For personal safety use an isolation transformner when troubleshooting.
Aug 03, 2011 | Chauvet LEDrain 36 CHVLEDR36
Using 24 chauvet par 56 led and chauvet obey 40. when going to bank 5, 6 or even 11, some fixtures will remain on while some will flicker. 2 fixtures per channel on the console. DMX addess starting at 1...
Read about terminating the chain with a resistor 120 ohms. If your run has appreciable length, a termination MAY be necessary to avoid digital reflections that can corrupt the message between the control and the lights. Having separate power sources CAN subject the units to "ground bounce" that can also corrupt the digital control. You need to power all the units from a single source or conditioner if possible. Another solution might be to use one of the DMX radio links which would isolate the ground problem. Another fix you MIGHT try is to get some of the clamsheel ferrite devices that clamp around the wires. Put these around the digital cables, not the power cords:
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=ferrite+core&cp=8&bav=on.2,or.r_gc.r_pw.&wrapid=tljp1304006132890014&um=1&ie=UTF-8&cid=761843538070174409&sa=X&ei=-Y25TaXFGsjYiALh_8ky&sqi=2&ved=0CFEQ8wIwAw#
Apr 28, 2011 | Chauvet (4) Chauvet Led Par 56-24c 7...
What kind of fuse do i need for it
The unit uses two 300 watt halogen lamps so it draws around 5 amps for just the lights and a small amount for the motor. The E108 is a carbon copy of the Chauvet Double Derby that used the halogen bulbs. My Chauvet is marked as using a 7 amp fuse for 120 volt operation or a 5 amp when used on 230 volts.
PLEASE open the unit if the fuse blew as it is likely there is an internal problem if nothing more than a light bulb that shorted as it burned out. There are slip rings and the sockets that need to be inspected if the fuse did blow.
Feb 25, 2011 | Eliminator E108 Double Derby Dj Light
Have a q-mix chauvet stage light goes thru all motions but light wont come on even changed bulbs and fuses alright
Chauvet uses a 16 amp Triac to control the power to many of the 120 volt lamps in their products. The Triac MAY be blown in your unit. If a bulb shorts, this blows the Triac.
I use Diigikey,com part number 497-2397-5 as the exact replacement. The generic number is BTA16-600BRG
Look for a part with this number on an aluminum plate and test the device. Also look for loose wires in the unit.
Sep 12, 2010 | Chauvet Followspot 400g with Stand
Where is the thermal fuse located on the Follow Spot?
Follow the wires internally. Close to the lamp you will find part of the wire that looks covered in another shield or wrap. Usually the thermal fuse is soldered in-line there. Chauvet will supply parts directly. Per their website: Call our Customer Service Department at 800.762.1084 (press #4). Tell us what part you need, we will give you the part?s cost plus shipping. Then we request your credit card information, charge your credit card, place the order, and ship out the part to you. Hope this helps, Dan
May 19, 2010 | Chauvet Followspot 400g with Stand
WHAT TYPE OF POWER CORD OR POWER PACK WILL I NEED WITH THE CHAUVET DMX 60 TIGER WHICH I LOST AND THE WEB SITE WERE I COULD BUY ONE
Sep 27, 2009 | Chauvet Dmx 55 Dmx Controller
Chauvet Cirrus Led Laser Dj Club Dance Effect Light Logo
61 people viewed this question
Top Chauvet Music Experts
Vito Vacirca Jr.
Are you a Chauvet Music Expert? Answer questions, earn points and help others
