Question about Refrigerators
G/E PROFILE WIRING DIAGRAMS PSF26PGTA SB - Refrigerators
Where can I find a wiring diagram
AutoZone carries a compliment of wiring diagrams online...check out Repair Guides Wiring Diagrams Wiring Diagrams AutoZone com
for a direct link to the diagrams for your 92 Lesabre...specifically Figures 13 and 14.
Jan 03, 2016 | 1992 Buick LeSabre
Central locking wiring diagram
If you go to Kia.com you can create a free user profile and get all Tue factory wire diagrams for your sportage...it's free.
Jan 07, 2014 | Kia Cars & Trucks
Need manual for ge profile psf26pgta
You can get the manual here=> Use and Care Manual Other typs of manuals Here Let me know if you have questions, Thanks Sea Breeze
Feb 01, 2013 | GE Refrigerators
Need a wiring diagram for airbag system for 2003 grand cherokee
Just have this information in spanish...
We cannot send big scale image, then try to contact our service profile or emailed.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 15, 2012 | Cars & Trucks
I need a clear wiring diagram for the engine compartment on a 1989 Mazda B2200
Did you check your battery cable connections (ground and power)?
Bad starter?
I can provide diagrams for the electrical systems on your truck if you sign up for my Pro Services.
Just click on my profile picture below and go to my FixYa profile page. Click the tab that says "Pro Services". When the page opens up, click any of the services listed. (It doesn't really matter which one - they will ALL connect you with me) Sign up for Email support. Be sure to include the Year, Make, Model, Engine Size, and a brief description of what we are trying to fix in your message (just so I don't mix you up with someone else). You can also do this by clicking any of my ads that you may see on FixYa.
Nov 18, 2011 | 1988 Mazda B2200
Heated seats dont work, fuses ok, switches light up, no heat
That is a common problem with that vehicle. It is likely that the seat heating elements are burned out. To find out if this is the case, you must unbolt the seat from the floor so you can tilt the seat back and gain access to the electrical connectos for the seat elements. If you have power and ground at the connector with the switch turned on, then the seat element is at fault.
Other than this, there are several other reasons why the seat heaters possibly will not work. In these cases, you will need a digital meter to test the voltage on the seat circuits as well as a wiring diagram to help you know where to perform the testing in order to locate the cause of the problem.
I would be happy to provide you with the wiring diagrams (and possibly, other instructional diagrams) if needed. Just visit my profile by clicking the link next to mt screen-name below and when you get o my profile click on the "Pro Services" tab to take you to the list of services I can provide. Click on any one of these, or you can simply click on any of my ads that are on the FixYa site to sign up for email support and I will get the diagrams to you.
Dave (dttech)
Oct 23, 2011 | 2002 Lincoln LS
Horns where is horn relay 2007 honda civic
If you need help diagnosing your horn circuits, please vitit my profile or click one of my ads and sign up for email support. By doing this I can provide instructions, wiring diagrams and component location diagrams.
With all that said, the horn relay in your 2007 Honda Civic is located in the under-dash fuse/relay box (left end of dash)
Oct 22, 2011 | Cars & Trucks
I just need to know were to find free wiring diagrams
Hi again Tracy,
You are most likely out of luck if you are looking for FREE wiring diagrams. The rest of the world (including professional automotive technicians like myself) has to PAY for this information. However, if you can get someone to give you this information for free - you will have to let me know how you did it!
Incidently, if you would like to visit my FixYa Profile by clicking on my name below, you can click on my "Pro Services" tab and then click any of the services I have listed and sign up for email support.
Then send a message telling me the make, model, engine size, and type of transmission that the vehicle has and WHICH SYSTEM you need diagrams for and I will be happy to send them to you. Please note that complete vehicle diagrams are not available - I can only send a single system diagram to you - i.e. Ignition System, Engine Control System, Windshield Wiper System, etc.
Please also include your email address in the message so I can send them to you DIRECTLY, because I cannot send these through the FixYa site due to size restrictions and copyright issues.
Jul 26, 2011 | Heating & Cooling
SB for KP-57WS500
You can buy replacement here:
Appliance parts, electronics parts & more from PartStore.com
Buy also the service manual, you find it on same website , the manual has diagrams that you must follow to test and replace the faulty part.
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Psf26pgta
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
