Question about Windsor SR12 Sensor Bagged Upright Vacuum
How do you disassemble a windsor sensor s12 vacuum
3 Suggested Answers
CorvetteKing
  • 108 Answers
SOURCE: i have windsor s12 vaccum this one have brush up light on
The windsor Sensor brush indicator light will come on when:
  • Something stuck in the brushroller
  • Brushroller is worn and needs replacement
  • height is wrong (indicates a problem with height adjustment)
  • a bad circut board/sensor
more than likely your brushroller just needs to be replaced, very common.
Posted on Jun 05, 2009
  • 6 Answers
SOURCE: No Power to Windsor Sensor XP12
The Windsor Sensor vacs all have a removable handle.
The handle is inserted into a "socket" which has contacts to complete the electrical circuit.
The handle is held in place by a gray plastic lever.
If the lever is not pressed down completely, the handle is able to slide within the socket during regular use.
If the handle slides out far enough, the electrical connection within will be disconnected and the vac will have no power.
Simply lift the lever, pull up to remove the handle, and re-insert the handle fully, then press down firmly on the lever to lock the handle securely in place.
This is the first step to solve your problem and hopefully this is all that need to be done.
If this does not work, please repost here and I will help you all I can.
Note: I am a big fan of the Windsor Sensor vacs and find them to be easy to work on and a great vac all around!
Posted on Feb 25, 2010
How to fix sensor s12. red light for bag stays on even when vacuum bag is not full and the vacuum is clear
You most likely will need to change the Yoke assembly. There is a sensor built in that gets clogged with fine debris over time. This will take care of the problem.
Feb 09, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
I have windsor s12 red light for bag is full is on and it's not clogged. what next
Check the line going from the bottom of the vacuum to the bag, it may be clogged. A coat hanger can help you clear any jams, but be careful not to puncture the duct.
Jan 27, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
How do I replace the front bottom plate on my Sebo X4 Extra vacuum cleaner, this is the metal/plastic plate on the front base of the bottom of the cleaner (no visible fixings)
With the power head cover removed, you will see tabs on the inside of the chassis inline with the front bottom plate. Simply pinch the tabs with some needle nose pliers and push. I have included a link to the parts list as well as the front bottom plate. You will see by the picture what those tabs look like and how to remove the front bottom plate. 5411 HG Front Bottom Plate Windsor Sensor S12 XP12 SR12 86138280 allstar... http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Dec 09, 2014 | Sebo X4 Extra Bagged Upright Vacuum
The handle release on windsor s12 won't spring into place
You likely have one of two problems. Your return spring is broken, or your axle is bent. If your axle is bent, carefully inspect your chassis to be sure that the bent axle has not cracked or otherwise damaged the chassis. I have included a parts list as well as some links to these parts for your reference. http://windsorvacuums.com/partslists/s12_PARTS.pdf 2010 Axle Spring 86146570 windsor allstar javelin 5053 Windsor Sensor Axle 86137990 allstar javelin
Jun 17, 2014 | Windsor VS14 Versamatic Bagged Upright...
Windsor sensor vacuum lights flashing then motor shuts off
I've worked on these a lot. What I think you're explaining is the bypass flow switch which is a common failure. It's located in the base inside the auction side of motor housing...
May 01, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
My windsor sensor 12 inch vacuum is to hard to push. I bought a new one and its doing the same thing. My vacuum repair man says he cant fix the problem. My shoulders are sore from working so hard. Help
It\'s possibly the type of carpet you\'re using it on. The sensors use the brush speed and the amount of air flow to determine carpet height. Some berber, and tweeds make these things horrible to push. We sell sebo, who make the windsor and we\'ve had the same issue on random carpeting. We end up selling the G- Series units in these situations because they adjust manually so not to suck themselves tight to the floor. Sebo/Windsor make amazing products but there\'s just no helping this, it happens sometimes.
Happy Vacuuming!
The Vac Dr.
The Vac Dr is always happy to help. If you\'re having trouble finding someone to help contact us here.
Jul 20, 2012 | Windsor SR12 Sensor Bagged Upright Vacuum
How do you change the belt on a winsor sensor s12?
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Windsor vacuums.
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Apr 26, 2010 | Windsor SR12 Sensor Bagged Upright Vacuum
I have windsor s12 vaccum this one have brush up light on
Jun 03, 2009 | Windsor SR12 Sensor Bagged Upright Vacuum
My windsor s12 vacuum light says the bag is full but it is new?
It sounds like a blockage in the hose or in the yolk.I believe you can remove the hose from the machine to inspect and clear it.Also check the trapdoor on the bottom of the powerhead to be sure it is clear.While you are going through the machine check under the upright filter next to the bag to see if it is clear.Good Luck-Scott
Oct 10, 2008 | Vacuums
Windsor SR12 Sensor Bagged Upright Vacuum Logo
190 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
