Question about Panasonic ETXMM610MEF Power Supply
Power supply for npx610me-1 not work - Panasonic ETXMM610MEF Power Supply
M8000
1) Check if the power cord is working properly.
2) If you can open the desktop check the power supply is working properly
the fan of power supply must turn on when you do this
3) if the power supply does not turn on the power supply is faulty.
40 If it turns on then there is problem with motherboard
May 17, 2014 | Computers & Internet
Power supply
Any 450 Watt SMPS power supply is ok. Zebronic or Mercury retails around Rs.450 to 500. No need of costlier power supply like Corsair etc.
May 05, 2013 | MSI Custom 845 Ultra-c Ver:1 Motherboard...
My power supply does not work
In Win makes low quality power supplies... They typically have bad quality control thus many are DOA... The fact that Newegg.com sells 469 different power supplies and only stocks 1 model of In Win power supply speaks volumes.
May 18, 2012 | In Win (ISP250A20) 250-Watt Power Supply
Lost power supply and the box doesnt state the voltage or amp requirement.
The power supply is 12 Volt, the center pin is +. i'm currently using a 1 amp replacement power supply(as the origional one burned out years ago), so anything > 1 amp @12 volts will work
Sep 21, 2010 | V-Stream Xpert 1280x1024 LCD TV Box...
My computer went blank when turning it on
1) Computer isn't working, due to the Processor isn't working, due to a bad Power Supply.
Weak voltage power rail.
Enough power perhaps to light LED lights, and maybe spin fans, but not enough power to turn the Processor on.
Computer Power Supply's are rated in Wattage.
Volts times Amperes = Watts.
(Average computer power supply in a fairly new computer, is rated at around 300 Watts)
A) ALL of the LED lights combined, use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts.
C) A typical Processor may use 51 to 125 Watts.
Depends on what Processor it is.
Power Supply with a weak voltage power rail, can have enough power to light LED lights, spin fans, but not enough to turn the Processor on.
Solution?
Test the voltages of the Power Supply,
Or, use a KNOWN to be good Power Supply, that has the correct amount of power cables, the right kind of power cables, the correct size, and shape of the case, and enough Wattage, for a test unit..
A bad Power Supply is one of the leading causes of computer failure.
Sep 19, 2010 | Computers & Internet
MY POWER SUPPLY STOP WORKING
300mA is marginal. On CD start unit draws a little over 400mA for about 1/2 second. At moderate CD audio levels the unit draws right at 300 and at full volume 400mA.
Be certain of the polarity and voltage . On the unit I have the wire with the white stripe is negative. If you are using a non-regulated supply, the voltage could be higher than rated. I am using a 9.5 volt non-regulated supply and after input filtering I have 11.5 volts across the input cap, that is rated @16VDC
A non-regulated 12VDC supply will probably exceed this 16VDC
rating.
Measurements taken with Fluke 23 and Simpson 160
Jul 30, 2009 | Sony ICF-CD855VSIL Clock Radio
Power supply not working
Hello my friend, if one of your power supply's part is burned, your power supply won't work else if its work i has a short time to operate and it will be burned the whole board of your supply. Mainly the reason of burning your supply are the following: 1. The Electric supply  from the source is to high or above the limitation of your Power supply. 2. Your power supply is over capacity. 3. You're power supply board develop a liquid moisture inside that is why it shorted and eventually the board is burned.  4. The load of your power supply is overload due to some device you attach that is beyond to the limit of your power supply's wattage capacity.
Note: try to see the wattage or voltage or the capacity of your power supply can supply the electricity within your computer system. To ensure that it does not exceed the limit of your power supply's limitation.  I therefore reccomend that to avoid burning the entire power supply board from short circuit, it is recommended to replace your power supply to avoid incidents may arise.
Hope this advice helps your problem. If you need more assistance just reply to this post.  If this solution or recommendation is able to solve or help your problem then please rate it.  Thanks
Jun 25, 2009 | Office Equipment & Supplies
No power in the mother board requesting for the
NO POWER.
    Switching power supplies (the most common used PC's), cannot be adequately field-tested with V/OHM meters. Remember: for most switching power supplies to work, a FLOPPY and at least 1 meg of memory must be present on the motherboard. If the necessary components are present on the motherboard and there is no power:
      1) check the power cable to the wall and that the wall socket is working. (You'd be surprised!)
      2) swap power supply with one that is known to work.
      3) if the system still doesn't work, check for fuses on the motherboard. If there are none, you must replace the motherboard.
thanks
May 14, 2009 | Intel Motherboard
Power Supply fan is not working in ThinkCentre M50 8189 D6G
Thanks for asking ...simply check the power supply fan....remove the Power supply(SMPS) from your system 1st....then remove the fan in it....try to rotate it by hands.....if it is not rotating smothly then it needs lubrication & your power supply unit needs cleaning.....if it is working fine then check the fan power section in Power supply...
regards
Mar 14, 2009 | IBM ThinkCentre M50 PC Desktop
My original xbox has no power at all.could it be power supply?
It sounds to me like the PSB. (power supply board)  you can get them fairly cheap, but you have to know what version your xbox is.  If you are unsure, google "determining xbox version".  Then go to ebay or http://www.llamma.com/xbox/
Here is one for about $15
http://cgi.ebay.com/Xbox-System-Power-Supply-Board-PSU-V1-0-1-5-V1-6-New_W0QQitemZ230329485609QQcmdZViewItemQQptZVideo_Games_Accessories?hash=item230329485609&_trksid=p3286.c0.m14&_trkparms=72:1234|66:2|65:12|39:1|240:1318|301:0|293:1|294:50
Feb 18, 2009 | Microsoft Xbox Console
Panasonic ETXMM610MEF Power Supply Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
