I have been told that my HIPS Firewall Help Service has stopped working and that Microsoft Windows can not find a solution at the moment...is there anyting I can do? also when I run a search for solutions for other problems I never get any solutions?
  • 33 Answers
Had this just happened or an ongoing problem? If this is the first time, just restart your computer and the problem should resolve itself.
Posted on Jan 25, 2009
Windows firewall service error code 5
If this fixit didn't work (http://support.microsoft.com/kb/2271812), make sure all of your windows updates have been applied. Once system is completely updated, try the fixit again.
Jun 05, 2013 | Microsoft Windows Vista Home Premium with...
Isa server firewall service stop
if you want to start the firewall service -go to control panel--- administrative tools---services---windows firewall----select it and double click on it---press START and select automatic then apply and ok. After this ----start----control panel----select windows firewall-----double click on it------select on----then apply and ok.Firewall services will be started.You can check now or you can restart the window before checking.
Jun 07, 2011 | Microsoft Windows Server 2003 Enterprise...
I can't turn on windows firewall. respons message: windows cant running ics service
The Windows Firewall Service not started.
Now to fix:
1. Click Start > Run > Type services.msc
2. Scroll down to Windows Firewall/Internet Connection Sharing (ICS)
3. Double click it.
4. Change startup type to Automatic and Click Start.
5. Click Apply and then OK
6. Reboot.
To reset the Windows Firewall to the factory default state, try this:
Type firewall.cpl in Start, Run dialog.
Click the Advanced tab.
Click the Restore Defaults button.
Click Yes to continue when you see this dialog
Restoring the default settings will delete all settings of Windows Firewall that you have made since Windows was installed. This may cause some programs to stop working.
Alternately, you can use the NETSH command-line to accomplish this:
Open a Command Prompt window and type NETSH FIREWALL RESET
This command resets firewall configuration to default. This provides the same functionality as the Restore Defaults button in the Windows Firewall interface.
or
Try this link @ http://support.microsoft.com/kb/914230
Hope it helps.
Note:- If you PC is infected with Malware & Spywarea that disable you have to clean up your PC first!!
Nov 14, 2010 | Microsoft Windows XP Home Edition Service...
Hi, when i try to install cisco vpn on my xp machine, it is throwing 1721 error.
Cisco VPN Client for Windows Vista, release 5.0.0.340, does not support the following:
blank.gifMicrosoft Windows NT, 98, and ME.
blank.gifSystem upgraded from Windows XP or earlier Windows operating systems to Vista. (Clean OS installation required.)
blank.gifCombination of Cisco Unified Video Advantage 2.1.2 and McAfee HIPS Patch 4 Build 688. To avoid system failures, uninstall either of these two applications, upgrade McAfee to the latest version, or use VPN Client 4.6.x.
blank.gifStart Before Logon.
blank.gifSmartCard authentication.
blank.gifIntegrated firewall
blank.gifInstallShield.
blank.gifAuto Update.
blank.gifTranslated Online Help. Online Help is provided only in English.
blank.gif64-bit Windows operating systems. For x-64 support, customers should explore with their Cisco sales representative the use of the next-generation Cisco AnyConnect VPN Client.
Nov 04, 2010 | Microsoft Windows XP Professional
I cannot download the new windows updates-I get an error message 646 and cannot find out what that means
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Download the standalone package file of the update “KB967043”
and install it.
Visit the following link to download the update:
http://www.microsoft.com/downloads/details.aspx?familyid=628280fe-e035-4274-85f2-393d9bad543c&displaylang=en
Restart the computer once the update is installed.
Let me know if this worked.
Oct 15, 2009 | Microsoft Windows Vista Home Premium with...
What is the different between xp serrvice pack 1 and 2
A service pack is a collection of all updates released to that point, and often includes new features, as well.
The major enhancements in Windows XP Service Pack 2 include Security Center, Automatic Updates, Windows Firewall, and Internet Explorer.
Security Center is an entirely new feature provided by Windows XP Service Pack 2. The Security Center service runs as a background process in Windows XP and routinely checks the status of the following components:
1. Windows Firewall: Security Center detects whether Windows Firewall is enabled or disabled. Security Center can also detect the presence of some third-party software firewall products.
2. Automatic Updates: Security Center detects the current Automatic Updates setting in Windows XP. If Automatic Updates is turned off or not set to the recommended settings, the Security Center provides appropriate recommendations.
3. Virus Protection: Security Center detects the presence of antivirus software from many third-party organizations. If the information is available, the Security Center service also determines whether the software is up-to-date and whether real-time scanning is turned on.
When Security Center detects an important security condition (such as improper settings), it displays a pop-up notice in the notification area.
Windows XP Service Pack 2 provides several enhancements to the Automatic Updates feature, including the following:
■ The latest version of Automatic Updates offers expanded support for Microsoft products, including Microsoft Office.
■ Previous versions of Automatic Updates could download only critical updates. Now Automatic Updates can download updates in the following categories: security updates, critical updates, update roll-ups, and service packs.
■ Automatic Updates now prioritizes the download of available updates based on the importance and size of the updates. For example, if a large service pack is being downloaded, and a smaller security update is released to address an exploit, that security update will be downloaded more quickly than the service pack.
■ Automatic Updates is now more automated. The need for users to accept End-User License Agreements (EULAs) has been eliminated. Also, the user now has a choice of whether to restart the computer following the installation of updates that might require a restart. Updates that do require a restart can now be consolidated into a single installation so that only one restart is required.
Previous versions of Windows XP include a software-based firewall named Internet Connection Firewall (ICF). After installing Windows XP Service Pack 2, this firewall is replaced by Windows Firewall.
Windows Firewall boasts a number of enhancements, including the following:
1. Windows Firewall is now enabled by default on all network
connections.
2. Windows Firewall provides an interface for configuring global settings that apply to all the connections of the computer.
3. In Windows XP Service Pack 2, Windows Firewall supports a new feature that allows you to keep Windows Firewall enabled and also not allow any exceptions; only solicited traffic is allowed. This new feature is intended to create an even more secure environment when connecting to the Internet in a public location or other unsecured location.
4. In Windows XP Service Pack 2, a startup Windows Firewall policy performs stateful packet filtering during startup, so that the computer can perform basic network tasks (such as contacting
DHCP and DNS servers) and still be protected.
5. In previous versions, you could not apply firewall rules based on Internet Protocol (IP) addresses. In Windows XP Service Pack 2, you can configure Windows Firewall so that firewall rules apply to IP addresses (or IP address ranges), meaning that only traffic from computers with valid IP addresses is allowed through the firewall.
6. In previous versions, you configure permitted traffic by specifying the TCP and UDP ports used by a service or application. In Windows XP Service Pack 2, you can also configure permitted traffic by specifying the file name of the application. When the application runs, Windows firewall monitors the ports on which the application listens and automatically adds them to the list of allowed incoming traffic.
Internet Explorer:
Windows XP Service Pack 2 introduces a number of new security features to Internet Explorer 6. As with the rest of the enhancements introduced with Windows XP Service Pack 2, most of the updates to Internet Explorer are intended to provide better security.
Jul 16, 2009 | Microsoft Windows XP Professional With...
Firewall is not allowing my computer to operate properly
You shall be an Administrator to log in , Go to Start + Control Panel + Windows Firewall and disable.
Apr 02, 2009 | Belkin (F5D7230-4) Router (587009)
Cannot turn windows firewall on/off
Mcafee should have a built in firewall. Have you tried to turn off there firewall? If not then give it a shot. Also you can unistall Mcafee and then reinstall it after the printer is installed
Feb 06, 2009 | Microsoft Windows XP Home Edition
Csrcs.exe spyware
This was posted via symantec: link:
http://www.symantec.com/security_response/writeup.jsp?docid=2003-053013-5943-99&tabid=3
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Click OK.
  5. In the Registry Editor, navigate to the following subkeys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    RunOnce
    RunServices
    HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\
    RunServices
    RunOnce
    HKEY_CURRENT_USER\Software\Microsoft\OLE
  6. In the right pane, delete any values that refer to the file names that were detected.
  7. Navigate to the subkeys:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wscsvc
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\TlntSvr
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\RemoteRegistry
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Messenger
  8. In the right pane, reset the original value, if known:
    "Start" = "4"
  9. Navigate to the subkey:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa
  10. In the right pane, reset the original value, if known:
    "restrictanonymous" = "1"
  11. Navigate to the subkey:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\
    parameters
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanworkstation\
    parameters
  12. In the right pane, reset the original values, if known:
    "AutoShareWks" = "0"
    "AutoShareServer" = "0"
  13. Navigate to the subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate
  14. In the right pane, reset the original value, if known:
    "DoNotAllowXPSP2" = "1"
  15. Navigate to the subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\OLE
  16. In the right pane, reset the original value, if known:
    "EnableDCOM" = "N"
  17. Navigate to and delete the following subkeys, if present:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\BoolTern
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\Root\LEGACY_BOOLTERN
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\rdriv
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\Root\LEGACY_RDRIV
  18. Exit the Registry Editor.
5. To delete the zero-byte files from the Startup folder
Follow the instructions for your version of Windows:
Note: There may be legitimate files on your system that start with "tftp." Delete only the zero-byte files from the Startup folder.
To delete zero-byte files in Windows 95/98/Me/NT/2000
  1. On the Windows taskbar, click Start > Find (or b) > Files or Folders.
  2. Make sure that "Look in" is set to (C:) and that "Include subfolders" is checked.
  3. In the "Named" or "Search for..." box, type, or copy and paste, the following file name:
    tftp*.*
  4. Click Find Now or Search Now.
  5. Delete the files that are zero bytes in size and contained within any folder whose name ends with "Startup."
To delete zero-byte files in Windows XP
  1. On the Windows taskbar, click Start > Search.
  2. Click All files and folders.
  3. In the "All or part of the file name" box, type, or copy and paste, the following file name:
    tftp*.*
  4. Make sure that "Look in" is set to "Local Hard Drives" or to (C:).
  5. Click More advanced options.
  6. Check Search system folders.
  7. Check Search subfolders.
  8. Click Search.
  9. Delete the files that are zero-bytes in size and contained within any folder whose name ends with "Startup."
6. To reenable the SharedAccess service (Windows 2000/XP only)
The SharedAccess service is responsible for maintaining Internet Connection Sharing and the Windows Firewall/Internet Connection Firewall applications in Windows. (The presence and names of these applications vary depending on the operating system and service pack you are using.) To protect your computer and maintain network functionality, re-enable this service if you are using any of these programs.
If you are running Windows XP with Service Pack 2 and are using the Windows Firewall, the operating system will alert you when the SharedAccess service is stopped, by displaying an alert balloon saying that your Firewall status is unknown. Perform the following steps to ensure that the Windows Firewall is re-enabled:
  1. Click Start > Control Panel.
  2. Double-click the Security Center.
  3. Ensure that the Firewall security essential is marked ON.
    Note: If the Firewall security essential is marked on, your Windows Firewall is on and you do not need to continue with these steps.
    If the Firewall security essential is not marked on, click the "Recommendations" button.
  4. Under "Recommendations," click Enable Now. A window appears telling you that the Windows Firewall was successfully turned on.
  5. Click Close, and then click OK.
  6. Close the Security Center.
Windows 2000 or Windows XP Service Pack 1 or earlier
Complete the following steps to re-enable the SharedAccess service:
  2. Type services.msc
    Then click OK.
  3. Do one of the following:
    • Windows 2000: Under the Name column, locate the "Internet Connection Sharing (ICS)" service and double-click it.
    • Windows XP: Under the Named column, locate the "Internet Connection Firewall (ICF) / Internet Connection Sharing (ICS)" service and double-click it.
  4. Under "Startup Type:", select "Automatic" from the drop-down menu.
  5. Under "Service Status:", click the Start button.
  6. Once the service has completed starting, click OK.
  7. Close the Services window.
Jan 13, 2009 | Microsoft Windows XP Professional
Keep gatting error code 80073715 on windows update!
You can try the following and it should clear it up.
Rename the SoftwareDistribution folder in C:windows (it will be recreated next time you visit Windows Update again)
You will lose your history but that's not important.
If the above step doesnt clear it up continue below:
Click Start, Choose Run.
In the Run box, type services.msc.
Click OK.
Right-click the Automatic Updates service. ( with Vista it may read Windows
Update)
Click Stop.
Stopping the service will take a moment.
Rename the "SoftwareDistribution" folder:
a. Click Start, click Run, type %systemroot%, and then click OK.
b. Right-click the SoftwareDistribution folder, and then click Rename.
c. Type SoftwareDistribution.old, and then press ENTER to rename this folder.
Click Start. Choose Run.
Click OK.
Click Start.
Starting the service will take a moment.
Retry Windows Update before reading further.
If you need to reinstall the ActiveX controls (because they may have become
corrupt):-
Follow this article (the article is listed the download for the old client) -
The Windows Update Web site and the Microsoft Update Web site do not scan
for updates when
you repair a failed installation of Windows XP Service Pack 2 or of Windows
XP Service
Pack 1
http://support.microsoft.com/kb/916259
Note: WU Client 3.0 - Windows Update Agent
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x86.exe
Thanks
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
