Question about Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum
I CAN'T PUT IT BACK TOGEATHER
How to put back togeather a electrolux el6989
Did you take it apart, or did somebody else? Those can be tricky. Take it to your local vac shop and have it assembled. I've been working on vacs for nearly 30 years and I can tell you, that is one of the worst ones to get together.
Feb 18, 2015 | Electrolux EL6989A Bagged Canister Vacuum
I need to know how to put my dyson switch back togeather
Hi, if you go onto you tube and type in how to replace dyson dc17 animal switch you should find on there or try espares they have different videos and i am sure i seen it on one of the sources given just a week ago.
Jan 31, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
I need to put the neutral pedal back together
will need to get Kirby engineer to repair, should cost 39 callout+28 for new pedal
Jan 11, 2013 | Kirby G6 Bagged Upright Vacuum
How do I put the rear wheel back on? Is there a diagram? I won't stay on any longer.
see the diagram.however you can download from www . retrevo.com or www.fitness.manualsonline.com God bless you-------------------------------------------------------------------------------------------------
Jul 10, 2012 | Vacuums
How can i put the forward lock back into my dyson dc14 animal?
I'm sorry to hear you've experienced this issue with your DC14. I'd encourage you to get in touch with us directly, as we'd appreciate the opportunity to provide further assistance.
You can call us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - we'll look forward to helping you resolve this.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 03, 2012 | Dyson Vacuums
Cannot put dc24 hatch seal back on
I'm sorry to hear you're having difficulties with your DC24. If the seal has come off, it's probably best if you contact us directly, as one of our advisers should be able to talk you through refitting this part over the phone. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US) - we'll look forward to hearing from you.
Best wishes,
Jack
Feb 05, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Chord plug broke
go to any hardware or home store even dollar shops --where ever u choose to go buy a replacement/repair plug .this is not a hard repair cut off plug end strip cover back 1 inch and strip back the wires separate the repair plug usually 2 or 3 little screws- slide wire up into sleeve and connect green wire to u shaped connection- white to silver color[sometimes the connections are not colored ] -black to goldish connection put plug togeather and ur done
Dec 18, 2011 | Electrolux Vacuums
I have a Bissell PowerSteamer ClearView How do I
I removed the pump belt and the brush drive belt for replacement. I can see that the brush belt has little ridges to line up on the brush gear. Its the pump belt that I need help with. The flat belt goes over the shaft sticking out of the pump, but the other end appears to have a channel that the belt fits into and around. Only when I put it togeather that way the belt is off center, does the belt fit up over the rounded (pink) end before the channel or is it supposed to fit in the channel
Jan 05, 2010 | Bissell 8806 Powersteamer Upright Vacuum
Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum Logo
24 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
