Question about Whirlpool LGR8648 Gas Dryer
The heating element in my GE dryer automatically turns on once the dryer is plugged into the wall?
  • 2,071 Answers
There a problem of the switch of the dryer it is shorted already .Just try find which causes the short or simlpy clean the circuit board connection.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
How to install a heating element in the GE wall mount dryer
GE Dryer design (Most or almost)....
Heating element access is from the front.
1. Remove the Front Door
2. Remove the belt.
3. Remove the Drum.
You see the heating element. Very simple design
Apr 06, 2015 | GE Dryers
Hotpoint dryer (nvl333eyoww) not heating
The thermostat and element are mounted on the back wall of the dryer. To gain access you must remove the drum. Here is my home movie:
My home movie and repair photos for GE hotpoint dryers
Dec 02, 2012 | Hotpoint Dryers
I have a GE Profile Harmony Dryer. No Power. 240v, 110v, 110v at the outlet but soon as I plug in the dryer I see 240v, 110v, 0v. Is the problem in the dryer or the power outlet on the wall?
Its not really clear to me where your measuring once you plug in the dryer, but all phases are measuring the correct voltage before, it appears you have an open circuit once you plug the dryer in. Now a dryer is 2 phase, so I would check all of your wiring connections, I would also check your circuit breaker and try swapping it out with a new one(as a last resort). Do some experimenting. In a dryer the heating elements are the only thing that runs on the 240V power. I would swap the hot leads in the dryer and see if any of the electrical components come on. Also try testing the continuity on your dryer plug wires to make sure there isn't a break in them (which can be proven by swapping the leads because now the same lead will read 0V on the other terminal).
Mar 31, 2010 | GE Profile Harmony DPGT750EC Electric...
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
How do I get to the heating elements in my dryer. It is a ge model 5 cycle automatic heavy duty extra large cap
there is a metal panel on the back that bolts on remove it then you will see a metal tube and it will have wires to it and a place to remove 2 or 4 screws to remove the area with the wires these wires attach to heating elements its easy to spot once back is off
Oct 26, 2009 | Dryers
DRYER SPINS BUT WILL NOT HEAT
The heating element is located in a pan on the rear wall of the dryer. You must remove the front and drum to access it. Start by opening the door and removing the screws that hold down the top. Then you can easily get the front off. In a GE dryer almost 100% of the time it is going to be the heater element.
When restringing the heater...READ MORE
Mar 19, 2009 | Whirlpool LER4634J Electric Dryer
JUST CHANGED MY GE DRYER TO A 4 PRONG PLUG, NOW NO HEAT
Sounds like your heating element is burned out (acually burned threw) when you moved it if the element was weak it may have broke in two along the coil wires.
Happens alot.
Feb 17, 2009 | GE Dryers
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Whirlpool LGR8648 Gas Dryer Logo
66 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
