Question about Sony XAV-701HD
XAV-701HD will it fit into an audi a3
I want to buy it but i wanna know if it fit to an audi a3 without me cutting and joining wires .
Does my 2008 Audi a3 quattro have a conector in the boot for tow bar wiring
unlikely
but the tow bar shop will have a harness that simply clips in to the existing harness as a piggy back arrangement
as the shop to have it fitted when you get the bar fitted
as a tow bar is a modification to the original vehicle specifications , you will need a modification plate to make the fitment legal and that is supplied by the shop doing the modification
Oct 29, 2016 | 2008 Audi A3
Can I buy a VR500CSBT connecter to female ISO connecter to fit VR500CSBT in my Vauxhall Corsa as I don't want to cut the indvidual wires of the conecter that came with the stereo and join it to an
they sell wiring harnesses that connect to the car manufacturers radio/player harness with wires to connect to after market players, do they sell one for your car? not sure
Mar 10, 2013 | Roadmaster (VR500CSBT)
Where can I buy a wiring harness for a Sony XAV-C1 Car DVD Player?
hi my name is lue and am located in lynwood california and i just bought a harness for the same model and willing to loose a few bucks to get some money back.. let me know if youre still interested..
Jul 27, 2012 | Sony XAV-C1 Car DVD Player
How do you take the dah apart on a 2000 Audi A3 1.9TDI to get to the wiring behind the radio?
How will you know what they did wrong even if you get it apart without doing more damage? No this is a job for a professional.
May 03, 2012 | Cars & Trucks
Need to know firing order on audi a3 1997 and the order from coil pack as we fitted new coil pack now car will not start car was running on 3 now new coil pack fitted nothing
Fig. The 1.8L cylinder location as viewed from the front of the vehicle. The firing order is 1-3-4-2
The above is for an Audi A4 from 1997. I didn't find an A3, unfortunately, in the U.S. market, on the Autozone.com website.
Jan 08, 2011 | Audi A3 Cars & Trucks
I have an a3 which is satellite but without the module. Audi wants $1000 for the module and aftermarket solutions? I see on the XM site they list several modules, but not one for Audi. Another choice is...
dont bother as it wont be long before you can use your mobile phone for satnav(we already have them in europe.....) hand held/cars fitted with satnav are old hat and EXPENSIVE for what you get.(the apple iphone is one. )
May 04, 2010 | 2008 Audi A3 S Line Hatchback
How to adust audi a3 door, it has dropped about
if hinges are in good order, then ,with the door ajar "adjust" by grabbing hold of the bottom of the door edge and lifting upwards a little at a time to get correct fit,a common problem with heavy doors nowadays....
Mar 17, 2010 | 2007 Audi A3
Need to find a switched earth for a tow bar fitted to audi a3 its for a 12s type plug and for the fridge pin number 7
you can get a switched ground useing a live wire to switch a rely to provide switched ground.live power to pin 85 ground to pis 86 and 30,the pin 87 will be negative whe the key is on.
Jul 05, 2009 | 2005 Audi A3
Audi A3 1.8t 1998 - lights alert - handsfree gadget
Your A3 should sound a warning beep if you leave your lights on. For this to happen the light switch would be in the side, or dipped position, the key out of the ignition and the drivers door open. If it does not sound the car may not be getting either the door or key signal. To check the key out signal, key the ignition to the on position, turn on the radio (probably only work if a standard radio is still fitted) then key off and remove key, if the radio goes off, its a good sign thats ok. For the door signal make sure opening the drivers door brings on the interior light on, this shows it recognises when its open. Let me know if anymore advise is needed.
As for the mic wiring, as far as I'm aware there were no standard/optional phone kits for this age A3.
Apr 01, 2009 | 2005 Audi A3
Radio wiring problem 2001 Audi A3
Hi, had total issues with this too! Your back speakers arent going because they are amped by the factory amp in the boot. You have to provide power to the amp so that it will turn the rear speakers on. This was a white and black striped wire in my car (Audi A3 1997) The rear speakers are blue /green and brown/red (left rear) , and the LH rear is brown/red and (forgotten colour) but the wire on the bottom left under those two brown/red wires on the 20pin harness. If you wire it all up like this then your rears should be going :)
Feb 21, 2009 | 2005 Audi A3
Sony XAV-701HD Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
