Big leak - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Posted on Jan 18, 2013
My break pedal goes to the floor
There are several causes for the brake pedal going to the floor:
- Broken seals in brake`s principal pump.
- Broken seals on rear brake's cylinder. (big lieak on wheel)
- Worn rear brake shoes, making seal travel out of cylinder. (big leak on wheel)
- Leak on tubings.
- Empty brake fluid deposit.
Nov 10, 2013 | 2001 Hyundai Accent
Bad oil leak in 2001 ot cruiser
A couple of leaks can be fairly large. An Oil Pan leak where you will see oil seeping down the sides of the pan and dripping directly below. The other is a Rear Main Bearing Seal leak and the oil will be coming from where the engine meets the transmission.
Aug 12, 2017 | 2001 Chrysler PT Cruiser
Flames coming up vent
Have you or someone converted this fryer to LP and/or back to Natural Gas? This sounds like your orfices are too big and the flames are shooting out, with leaking gas around the orifice itself? I would have the orfices redrilled, so you know they are correct, as this is dangerous... The only other reason you would have fire outside the designated area is because of a leak. When the pots leak, you will sometimes have the oil leaking catch on fire and burn around that leak area... You don't have a leak, do you? My best guess is the orfices are too big...and someone drilled them out that way...too big... Any further question or if you need new orfices, please call Paul or Susan at Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959. Thanks, Susan
Sep 10, 2011 | Pitco Frialator 40CNG Deep Fryer
.Dear's I have Audi A6 2.6L
These cars leak! Regular services can usually find and fix these leaks as they happen. Valve cover gaskets and cam Phasers are one big one that drips on the exhaust manifld and stinks up your car. Oil sending units and oil coolers are big on these cars also.Good Luck.
Sep 15, 2010 | 1997 Audi A6
Antifreeze leaking from the engine how big of a job to change the headgasket
before spending money on a big job try BAR S LEAK OR SOME OTHER TREATMENT THEY DO MIRACLES I DID IT TO MY 2000 GRAN AM 4 YEARS AGO AND IT S STILL RUNNIND
Jun 19, 2010 | 1997 Buick Skylark
I have a mitsubishi montero sport utility truck and my servic engine light came on, i noticed that it was leaking when i parked it, what do you think it can be?
As far as the engine service light, I'd go to Autozone and have them read the engine codes2_bing.gif. They'll do this for free at most autozone parts places. The codes will indicate what's wrong and you can then decide if you really need to fix it. As far as the leak, it all depends what is leaking and how quickly it leaks. Leaking a little engine or trans fluid is not a big deal. Leaking any brake fluid is always a big deal.
Mar 10, 2010 | 2003 Mitsubishi Montero Sport
How much work is it to fix a leak. it is spraying out anti freeze up by the motor. It looks like maybe the where the seal may go
If the leak is a hose, not a big deal. Drain antifreeze disconnect hose, instal new hose, refill antifreeze. If the leak is a water pump also not a big deal, same procedure.
If the leak is in the radiator, a bit more complicated. Radiator can be replaced or repaired by a radiator shop.
If leak is coming from somewhere else on the engine, could be more serious, like a gasket leak. If this happened you would get fluids mixing ( oil/gas)
Good luck. A Haynes manual is a good investment for your car.
Feb 05, 2010 | 1997 Oldsmobile Achieva
P1299 vacuum leak found IAC FULLY SEATED IS THE FIRST CODE THEN P0455 EVAP SYS BIG LEAK
was the fuel fill cap ever left off or fueled while running. this would trigger that. a big leak could possibly be a broken vacuum hose. that would aslo explain the iac code.
Dec 17, 2009 | 2001 Chrysler 300M
Got jeep some times leaks coolant sometime it dont have gone couple weeeks without leaking at all what can be leaking
sounds like a bad waterpump. keep an eye on waterpump may be leaking. start there good luck.
Oct 29, 2009 | 1994 Jeep Grand Cherokee
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
