I have a hotpoint first edition 800 wm 51 can you tell me is it east to change the bearing in the drum
  • sye87 Jan 25, 2009
    thank you ...but i need to know how to change the bearing
  • Washing Mach... Master
  • 3,463 Answers
It is a fairly straight forward repair to do, if you know what you are doing.
The bearing comes as a bearing kit, consisting of 2 bearings and a shaft seal, yuo will also need a new container front seal, and depending on how badly the bearings are worn, you may need to fit a new drum shaft as well.
Again depending on how badly the bearings are worn, they can cause wear in the bearing housing, this being the case, then you would have to fit a new outer tub.assy complete,
This then puts it beyond economical repair.
Obviously , you will not know what is req'd until it is stripped down.
Plz rate my comments towards providing a solution to your problem.
Thankyou.
Posted on Jan 25, 2009
Drum will not turn
Remove the back panel or look under the unit. There is a belt that goes from the drum to the motor. Either the belt is broken or the motor is no good anymore
May 06, 2010 | Hotpoint First Edition FEW10P Front Load...
How to replace bearings on a hotpoint washing machine ,will i have to remove the drum,if so does it come out the top ,front,underneath.
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our sitehttp://www.apart4u.co.uk
This first video shows you how to diagnose the problem
utube.png You-Tube video "kG5HWQ0x2s0" placeholder (do not delete) utube.png
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Apr 10, 2010 | Hotpoint First Edition WMA20 Front Load...
Hotpoint WT540 Bearing Change. I have got the drum out but I am having problems spliting the drum. Is it bonded or are there any tricks I can use to split the drum without destroying it
If there are no visible screws or other obvious means of the 2 drum halves being joined together, then it is not possible to change the bearings, as it is a one piece drum.
Current models are one piece, earlier models had screws securing the drum halves together,
Hope this helps..
Jan 11, 2010 | Hotpoint First Edition FEW10P Front Load...
Washing machine very noisy on spin
Oct 21, 2009 | Hotpoint First Edition FEW12 Front Load...
Hello there, I am trying to source a drum bearing for a Hotpoint WMA22 washing machine. Is a WMA22P bearing suitable? Only I have found two sizes advertised for a WMA22P (30 & 35 mm) Thanks, Clive.
Oct 05, 2009 | Hotpoint First Edition WMA22 Front Load...
Bearings have gone
For all your parts visit our site http://www.apart4u.co.uk
Jun 02, 2009 | Hotpoint First Edition WMA12 Front Load...
Need to change bearing!!!
How do I change the drum bearing on a 800 electronic 9506 hotpoint front loader washing machine, please
Nov 10, 2008 | Zanussi Washing Machines
Out of balance spin
next time its empty open the door take the metal drum and test for any movement if you hear/feel a knocking the drum bairings need replaced, makes it spin if centre
Oct 04, 2008 | Hotpoint Washing Machines
Hotpoint WM A54
about the same level of difficulty as zanussi. however on some wma series the bearings are not available seperately - new drum and tub- so check first
Sep 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint first edition wma 11 drum bearings removal
Hey kevin that outer cone of the front bearing is a mission im telling ya...
But from experience ive found that by cleaning around it ( i use a metal brush on a drill ) and using wd40 and letting it soak in for a few hours its makes like a lot easier,,
I use a bolster with an end similar to a crow bar to just get inbetween the tiny gap and a very big lump hammer to know out the cone.... Best way knocking it from side to side ie bottom the turn the back half of the drum round and knock the top then the sides,,
hope this helps....
cheers mate..
Jan 10, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
