Accent air flashing E-C - Heating & Cooling
HYUNDAI Accent 2000 when accelerating it suddenly looses power?
Do you have a check engine light on or flashing when it looses power?
Aug 31, 2016 | 2000 Hyundai Accent
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
Check engine light flashing on idle 2007 hyundai accent and sputtering. Previous (2 months ago) P0496 code caused steady check engine light. Some roughness noticed when accelerating steady below 60 km per...
Dont drive a car with the light flashing. A flashing check engine light means that something is really wrong and you can damage the engine if you drive it.
Nov 04, 2013 | 2006 Hyundai Accent
2002 hyundai accent wont rev passed 2500 rpm,
Have the fault codes read Replace the faulty units with genuine one because most aftermarket units are not set
for OEM cpu units and are not completely compatible
May 05, 2013 | 2002 Hyundai Accent
Check engine light is flashing on 2007 hyundai accent
If its on solid, you need to scan it soon. If its flashing it means its urgent & u need to pull over & turn off the engine!
Jan 10, 2011 | 2006 Hyundai Accent
I have a 2002 hyundai accent, i could not pump gas into the tank, i found charcoal pellets in the hose from the evap canister to the tank fill neck. I emptied the hose and i can pump gas. now my car is...
First GUESS.. replace the charcoal canister after you have cleaned out the hoses between it and the canister. Then blow air between the purge control solenoid valve and the fuel tank.
Oct 23, 2009 | 2002 Hyundai Accent
Need to know what the box is called that holds the air filter on my 2007 hyundai accent
commonly this is called an air box, but describe it as an air filter box or chamber, to avoid confusion
Sep 09, 2009 | 2007 Hyundai Accent GS Hatchback
No air blowing when I turn on the air conditioning on 02 Accent
no air con gas you need it top up?or a new fan motor ?you will fine this on ebay
May 12, 2009 | 2002 Hyundai Accent
2000 accent keep getting check en light on codes 300, 303
try having the crank sensor tested and the coil packs hope this helps
Mar 04, 2009 | 2000 Hyundai Accent
light will flash when accellerating,if this is the case ,it s misfirering, car must stumble,check scan code,spark plug wires coil pack,
Feb 22, 2009 | 2002 Hyundai Accent
Heating & Cooling Logo
616 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
