Question about Sharp AL 1631 Copier
Flashing "ch" when i plug it in the wall it lights up sounds like it is initializing but only flashes "ch" with all green lights on accept the copy ready flashes but goes out. any help is appreciated.
    New Friend:
  • 16 Answers
Hi Yes one of your covers is open, or the accuator that pushes the micro switch/optical switch has dislodged or broken. Fix the cover or repair/replace the swicth. Regards
Posted on Jul 16, 2007
SOURCE:
Replaced power supply and reset still on light no sound just a flashing green light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec.
Press Input & Ch Down Switch from LED panel and plug in and start LED
LED will start and "K" will appear on screen
Press Ch Down & Vol Down switch at same time
You will get 1/10 page on screen
Go to 9/10 page by pressing left & right button from remote
Select EEP and press Ok button from remote
After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
How do I stop the green light from flashing Sharp 46 aquos
Remove Main's plug press Input & Ch.Down button from LCD and put Main's plug to start LCD.
You will get K on Screen press Vol - & Ch- from LCD
You will get 1/10 page go to 9/10 by pressing ch.- button
You will get EEP off screen press ch- button from remote and press
Right side arrow from remote and press OK
On screen you will get EEP running.
After finish this oprestion remove plug and restart LCD.
Oct 20, 2014 | Sharp LC Televison & Video
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
RYOBI CHARGER RED AND GREEN FLASHING LIGHT
Try rotating the plug that goes into the wall. I know it sounds irrelevant but ive had the same issue and it worked for me. The positive and negative may be reversed in the dock.
Jan 04, 2012 | Ryobi Multi-Volt Battery Charger
TV will not turn on. There are two lights in front at the bottom of the screen - One is the power light, one is the OPC light. When the power cord is plugged in, both lights flash twice, then the OPC light...
Sounds like your screen is broken or has been impacted. Force the television on by doing this: Unplug it and on the side of the television where the panel buttons are hold down the ch- and vol+ buttons. Then plug in the television while still holding them down. The television should come on and you see the cracks. Unfortunately it can't be repaired.
If it isn't ch- and vol + then try ch + and vol -.
Feb 05, 2011 | Sharp LC46SB54U 46 in. LCD TV
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Sharp AL 1631 Copier Logo
80 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
