Question about Toys
I have alionel multi-control transformer type1033.Idon't know how to hook it up there are 4 termanals U A B and C. I have a tender with a whistle but don't have a clue please help
The standard arrrangement on Lionel Transformers is that Terminal U is the Common or Ground or Base terminal. Wire your track connector to terminal U for the outside rail, and Terminal A for the inside (middle rail). This should provide between 5 and 16 volts ac to the track, under control of the throttle. Wiring between U and terminal B is a fixed output for certain accessories, and the same is true for U and C. I do not recall offhand what the voltages are supplied for those two outputs. You could borrow a voltage meter from someone and check that out.
Posted on Jan 25, 2009
I need a manual on how to hook up alionel ho train set no. 0602 bought around 1960
controller has two low voltage wires that go to either a terminal connection for track or to connections for either side if train rail
Nov 13, 2017 | Crafts & Hobbies
Lionel 2466WX Tender -- HOW do I get it to WORK? (Assuming that it does work)?
Good work, Dan! Fixing trains can be as much fun as running them.
Apr 22, 2014 | Crafts & Hobbies
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
No pix/sound, just high pitched whistle
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
Jun 06, 2010 | RCA 35V432T 35" TV
I have a 5 ton air conditioner made by international comfort corporation, it bears the model number PAB036N1LA and I need to know what the diagram is to hook up the thermostat. its a commercial rooftop...
on the unit it should have low voltage termanals labled R Y G H H2 the R termanal goes to the t-stat on the r termanal and the y to y on the t stat ang g to the g on the t stat and H termanal goes to h on the t stat etc if thers no termanal block find the low voltage wires and get back with me on the collors
Apr 04, 2010 | Heating & Cooling
I am trying to hook up a Lionel 1033 transformer to my Christmas train. What terminal goes to what? I want my old 2026 to smoke and my 6446W to whistle.
I have the original Instructions for Operating the 1033(written in 1953) - the second paragraph of the "How To Connect Transformer" reads as follows: The "Multi -Control" transformers listed in this leaflet have four binding posts located on the top of the transformers. Of these, "A-U" and "B-U" combinations furnish variable voltage for the track. The control arm of the transformer simultaneously regulate the voltage output of both the "A-U" and the "B-U" combinations. The transformer nameplate indicates the voltage ranges of these two combinations.The "A-U" combination supplies any voltage from 5 to 16 volts. The B-U combination has voltage from 0 to 11 volts. In selecting the proper range of voltage for your particular outfit, try the lower "B-U" combination first. If the maximum train speed is not satisfactory, then try the "A-U" posts.
To paraphrase the "How to Connect Accessories" section: accessories work best with fixed voltage - these voltages are obtained from the following pairs of output binding posts: "A-B" 5 volts; "B-C" 11 volts and "A-C" 16 volts.
Hope this helps, Mark
Dec 14, 2009 | Toys
My phone does not charge the battery
you will probly need to change the phone or if you have some knolage of electonilcs, open it up and take a multi meter to the components neerest to the batery termanals and the power input termanals. your problem will most likly be in those areas.
Dec 01, 2009 | Nokia 6300 Cellular Phone
Where can I find a wiring digram for the transformer it has 4 wires going into it on the hot side then to comming out on the 24 volt side.I took the old one out to replace it and cannot seam to get the...
It sounds as if you have a multi-tap transformer. That is, the primay voltage can be 120, 208/240, 480. Most all transformers have their legends printed righ on them. Usually the 4 wires are a common and the other wires to the incoming voltage by it's color. There is no industry standard that I know of. What is the brand of the transformer and does it have a part number?
Good Luck and hope this helps.
Jul 10, 2009 | Heating & Cooling
4position lnb ineed to know which termanal to hook uo to for a
do you mean 4 outputs if so it dont matter but for some reason i always use the one on the left first
Mar 19, 2009 | RCA D6520
Toys Logo
303 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
