Question about Toshiba 55HX70 55" Rear Projection Television
Won't lock on standard resolution
Replaced the STK392's. Problem solved. Then I was in the service menu doing convergence in 1080i mode. When I went to exit (press 7 . . .) I think I hit a wrong key. The TV switched to the off-air input while still in service mode. I hit a couple remote keys (bad idea). I ended up with great looking 1080i but the standard def resolutions look very bad. Colors are dramatically mis-converged. The set will shut down after a few seconds of this. The power led flashes. (I had my own shop for a couple decades but I am not transitioning to PDF manuals very well.) I would be very grateful for some clues or maybe a magic bullet. Thanks.
  • Paula Something Jul 14, 2007
    . . . except -- the TV shuts down in moments in the std def modes.
    President:
  • 3,130 Answers
LOL No such thing my friend. Thats what happens when you mess with the wrong buttons I'm afraid in the service maode. You will need to go back to the service menu and start over from scratch in the other scan modes. Sorry, no magic bullet
Posted on Jul 14, 2007
  • Larry  Dillon
    Larry Dillon Jul 17, 2007
    change the eeprom and start over
SOURCE:
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Convergence problems at 1080i resolution
With TV off ON Front Panel board Press and hold vol-&ch- at same time untill set comes back on you should now be in Service Menu ,try adjusting convergence then.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pt-53wx47f
you will need to do the convergenace adjustment for each different format then save each setting for each adjustment.
Aug 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Convergence service mode
I don't know how to deal with the power settings part but the convergence service mode is "Mute, 1, 8, 3, power".
Jan 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
VERTICAL PINCUSHION (NORTH & SOUTH PART OF SCREEN)
DUDE!!! Both manuals are available at http://www.servicemanuals.net/ I dont know where you tryed before to get a manual for these sets but both modela are available online at like 20 differant spots.. This one site is the one I trust the most, as they have 99% of any manual I have ever Needed. Good Luck
Aug 08, 2006 | Pioneer PRO-200 60" Rear Projection...
Open Questions:
See all Toshiba 55HX70 55" Rear Projection Television Questions
Toshiba 55HX70 55" Rear Projection Television Logo
283 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
