Question about Xerox Phaser 6010n Color Printer
Invalid cyan error code - Xerox Phaser 6010n Color Printer
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
HP Laserjet 5550dtn printer is giving error 59.51, what will be the problem?
This code means there is a Cyan Cartridge motor error. The most common cause of this error is the Cyan Toner/Drum cartridge is binding up and causing the motor to stop turning. I would try removing then re-installing the Cyan cartridge first and see if it goes away. If not then replace the Cyan cartridge with a new cartridge. If the problem persists then there is a problem with the drive assembly for the Cyan cartridge.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | HP LaserJet 5550dtn Printer
Invalid New Toner
You may need to get a new chip on the toner tray. If you go to the place that sold you the toner, they likely have the chip that you need.
May 20, 2010 | Samsung CLP-510N Laser Printer
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Error E000020-03a2 canon c6800
pls check the cyan deverloper if it irc6800.drum unit if it is irc3200
Mar 04, 2010 | Canon imageRUNNER C3200 Copier
Incorrect cartridge error
The Error is incorrect or Invalid .
The error invalid comes if the printer and cartridge does not belong to the same region.
Mar 27, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
Fatal Error 162
I am pretty sure this is the result for your 162 code:
Toner Sensor Error, Color:Cyan
When cyan toner sensor error has occurred
Try reseating your toner carts.
May 14, 2008 | OKI C5150n Led Printer
Kyocera Printer error - Help!
The code is for a defective cyan motor. So its either the cyan toner motor or a lump of toner inside the cyan toner container.
Feb 29, 2008 | Kyocera FS-C5030N Led Printer
Xerox Phaser 6010n Color Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
