Question about Brother HL 1870N Laser Printer
Error 503 Printer doesn't print
Printer error
First confirm if the printer is recognized by your system,and check the printing history to see if there is a queue. If there is, delete them and restart your system. This time, make sure it\'s recognized, then resend your instruction to print.
Jun 12, 2013 | Office Equipment & Supplies
Printer
The steps below should help you override the error and make the printer accept the cartridges and allow you to print.
Instructions
    • 1
      Remove and replace the print cartridge. If that doesn't solve the error, move on to Step 2.
    • 2
      Remove the print cartridge from the machine.
      • 3
        Wet the end of a cotton swab with rubbing alcohol.
      • 4
        Wipe the copper colored contacts on the print cartridge with the cotton swab to clean.
      • 5
        Wipe the contacts in the printer where the cartridge sits.
      • 6
        Replace the cartridge and try a test print. If removing residue for a clean connection didn't solve the error, move on to step 7.
      • 7
        Turn off the printer.
      • 8
        Unplug the printer from the power source and leave it unplugged for 15 to 30 minutes. This will reset the printer.
      • 9
        Plug the printer back into the power source and turn it on.
      • 10
        Print a test page.
    Regards,
    Suhail
    May 20, 2012 | Lexmark X1240 All-In-One InkJet Printer
    My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
    A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
    If that doesn't help, try the steps below:
    1. Disconnect the printer from your computer.
    2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
    2. On your computer, go to Control Panel > Printers and Faxes.
    3. Delete the Lexmark print object.
    4. Reboot your pc.
    5. When your pc turns on, reconnect the printer.
    6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
    Sep 14, 2011 | Lexmark Z2300 InkJet Printer
    Error code P03. It won't print, it doesn't make any noise when I turn it on, and I don't see any traces of paper.
    Error code PO3 is caused by Timing Disk dirty / damaged.
    Please use this methods
    1. Check the timing disk sensor located to the left of the printer
    2. Check and clean the board.
    And start to print... thanks
    Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    When i give a print command this error apears on the paper : pcl xl error subsystem:kernel error:illegaltag operator:0xfe
    1st: turn off your printer, wait 5 minutes, turn on again. Try to print again and see if the problem is solved. If this doesn't work:
    2nd: de-install your printer from your computer, download the latest driver for your operating system, install your printer again. And if this doesn't work, download the latest HP Laserjet generic driver and install it again.
    You can find the drivers on the support page from HP, searching for the model printer that you have and select the driver for your operating system (windows xp, vista, 7..)
    Aug 07, 2011 | HP LaserJet 1320n Printer
    My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
    Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
    Jun 18, 2011 | Lexmark X2670 All-In-One Printer
    Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
    Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
    To get rid of it there is a tool named printer spooler fixer.
    The link to get that is below.Just copy it and paste in your browser
    http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
    Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
    I can't print in my Canon Pixma IP1980... service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix...
    service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix this?
    Dec 08, 2010 | Canon Office Equipment & Supplies
    Brother HL 1870N Laser Printer Logo
    49 people viewed this question
    CheckitRight
    CheckitRight
    Ron Dufek
    Ron Dufek
    James Cagle
    James Cagle
