Question about Sony KP-41T65 41" Rear Projection Television
KP-41S3U WHEN I SWITCH IT ON YOU GET THE USUAL HISS NOISE OF POWER UP BUT THEN U GET 2 CLICKS LIKE A RELAY CLING SOUND .WHILE ALL THE TIME THE STAND BY LIGHT FASHES AND THATS IT IT JUST KEEPS FLASHING CAN ENY ONE PLEASE HELP ME .THANX
  • Anonymous Apr 19, 2008
    convergece
  • RAF786 May 07, 2008
    THW LED HAS A SEQUENCE 1 QUICK AND 1 LONG BLICK.CANNOT DO ANYTHING FROM REMOTE EITHER.CAN ANYONE HELP AS I REALLY LIKE THIS TELLY
I have a sony kp-41T65 burnt capacitor C514. need specs. Help please. Thanks
Posted on Apr 15, 2008
SOURCE:
Hi I have a sony kp-53HS10 TV. When i turn it on it use to make a clicking noise and than the tv would turn on, but now the clicking noise is gone and nothing comes on. A red light under the tv stays on....
Sounds like a Power Board / Video Board issue - stand by power is still ok - and why you have a red light - but the set is unable to power up the panel to drive a picture. Or the video board is the issue an is no longer processing the image to your panel. Based on the clicking noise - I lean towards the power board as the issue.
Dec 21, 2017 | Sony KP-53HS10 TV
KP-51WS510 blinking light but no picture at all. Audible click like usual followed by another click sound shortly after.
THE click is the relay on the power board coming on and then going off---red power light should blink a error code---when set shuts off (second click) watch the power light and count the blinks.
Let me know what you find.
SD TECH
Jul 28, 2010 | Sony KP-51WS510 51" Rear Projection...
Tv will not turn on
its a clicking of switching relay. cannot power on due to power supply failure.
May 30, 2009 | Sony KP-48S70 48" Rear Projection...
Won't start!
sounds like the starter solonoid(or relay) has gone on vacation with out you or the bike the clicking noise would be the (relay) solonoid trying to complete the circut to engage the starter
Jan 04, 2009 | 2008 Triumph Daytona 675
SONY KP-41S3U
tv sony kp 53u45 com centelhador proximo ao flay bak acendendo e desligando atraves da proteção.
como conseguir o esquematico da mesma
Jun 12, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-41S3U
Good Day;
On that model look for a small yellow cap, half the size of coin, dime. LOOK very closely and you will see a small burnt spot on the cap. The TV uses about 4 of them, they are 120/110 @ 2 kv. There are located in the high voltage circuit.
This the most common, it could be flyback or HV devider.
Good Luck and Day, big irish.
LET ME know.
Jun 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony kp-41s3u 50" hissing sound
sounds like high voltage arcing,caution
Oct 28, 2007 | Sony KP-41T65 41" Rear Projection...
Light blinking...but not coming on
This looks like a problem with the H Voltage or switching power supply section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, and check the voltage output of the switching power supply. What may have happened is a component may have shorted out causing an over-current condition with is triggering the shutdown circuit (These are the relays you are hearing). I would check the Horizontal Output transistor, and the components in that section of the TV.
In addition check the voltage test points on the HV / Horizontal and switching power supply board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I hope this helps,
Thank you,
Shuttle83
Sep 04, 2007 | Sony KP-46WT500 46" Rear Projection...
Klipsh Promedia 2.1
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Sep 10, 2006 | HP ProMedia Computer Speakers
Sony KP-41T65 41" Rear Projection Television Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
