Question about Bosch SHX43R55UC Dishwashers : Built in Dishwasher
I just installed a Bosch shx43R55UC/64. Upon stating all lights are on and I cannot select a cycle. When I shut it the unit starts but will not fill with water. The float switch is working, No wate
When I press the reset buttons the lights goes to clean but the unit will not stop running
SOURCE: Bosch SHU9925UC Dishwasher Stuck in Initial Drain Cycle
OK Bosch Dw fans.........here is the fix if your SHX dishwasher is stuck on the drain cycle. This may save you a couple hundred bucks.......so listen up. There is a tendency for the very small float switch to STICK in the ON position, which will cause the drain motor to continuously run......and DISallow any other function to work. DISCONNECT POWER. Did I mention to disconnect power? Take off the front base cover....2 torx screws. Remove the other 2 torx screws in the metal clips that fasten the top of the DW to the underside of your countertop. NOW...carefull slide your DW out. You may have to disconnect your water and elec supply if you do not have enough slack to pull it out. Once the DW is out of the cabinet, remove the shiny metal cover on the LEFT side by removing a single torx screw. You will now see a small plastic assembly with a red plastic piece that moves up and down as it rides on a small red styrofoam float. This up and down movement engages a small white plastic switch visible with 3 wires coming out of it. You can carefully UNSNAP this switch out of its mount, and pull the 3 wire plug off of it. THere is a small square blue plastic tab that is supposed to easily slide in and out of the switch. If it is stuck IN, you can sometimes tap the switch and the blue tab will pop out, which is what it is supposed to do without tapping it. You can carefully with a knife blade separate the case on this switch and note the way it comes apart. Clean out any micro debris out of the small channels that the blue tab ride up and down in. Then set it in the channel while holding up the small switch tab that rides on it and see if it slides up and down without sticking! I like to take a piece of wax paper and rub in on the channel and blue tap to provide some lube for the switch to slide easily on. Now, put the switch back on and manually move the red plastic assembly up and down while you are watching the blue tab. The tab should ride up and down with the red assy. If not, buy a new switch. Google the # on the switch and order one. If the tab slides up and down, put things together in reverse order and give it a try. Hope it works for you. This should take you an hour give or take. Take the $200 you just saved and have a night out on me. ........so even though these German Appliances have a good name because of past reliability, the american tendency to value engineer them with plastic parts to reduce costs and increase profit.........just cost you an hour of your time. Will we ever learn.? ......if it ain't broke, value engineer it until it only lasts through the warranty period so you can then collect service and parts blood money from your fellow american.
Posted on Jan 11, 2009
SOURCE: Bosch dishwasher sgs43c02gb cycle problem.
I found the problem for pump noise & water in bottom. The dishwasher hose connection under sink had small plastic piece stuck in narrow elbow
Posted on Feb 13, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Posted on Aug 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: New SHE4AM16UC, professionally installed eight
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 05, 2010
SOURCE: My Bosch integrated Dishwasher SGV5303 has stopped filling with water. An Aquastop unit is fitted but the filter in that is not dirty/blocked. Any ideas? Regards, Bob
The same thing happened to mine in March 2010
Posted on Apr 06, 2010
Bosch shu5316uc filling fault
Test the water inlet electro valves.
May 26, 2017 | Bosch SHU5316UC Dishwasher
WHY IS CYCLE TAKIN LONGER THAN IT SHOULD? 55MINS CYCLE IS TAKING AN EXTRA 40 MINS.
Could be due too one of several reasons.
The time is subject to various factors including, low water pressure, thus taking lomger to fill, poor drainage, temp of incoming water, temp of programme selected.
The time is based upon premium operating conditions.
Hope this helps.
Mar 09, 2010 | Bosch Washing Machines
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
My bosch excel dishwasher has the following fault: start the cycle, water starts to fill but then check water light comes on and it then starts to empty again. Pump then keeps going. I have checked the...
this unit im sure has a water flowmeter that measures the water intake.. if this cannot read then the unit shuts down to avoid flooding..
it needs replacing... it is attached between the valve and the side tank or attached to the tank dependant on model...thanks
Dec 18, 2009 | Bosch Dishwashers
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch Dishwasher will not power on
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Contunuous draining turned into a flood when unit powered off
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
May 09, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch SHX43R55UC Dishwashers : Built in Dishwasher Logo
47 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
