Question about Singer 160 Anniversary Limited Edition Computerized Sewing Machine
Singer 160 bobbin winder shaft not turning - Singer 160 Anniversary Limited Edition Computerized Sewing Machine
  • 3 Answers
SOURCE: Bobbin stuck on bobbin winder, how do I get it off? it will not budge!
Is thread under bobbin? can you turn it? can you pull the thread off the bobbin and then remove it? Bobbin that comes with machine may not be right one. Right one has a light blue tint and a slightly domed top.
Posted on Jul 08, 2007
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
dupina
  • 110 Answers
SOURCE: Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Posted on Jan 12, 2009
  • 76 Answers
SOURCE: bobbin winder "washer"
It's called the
"bobbin winder friction ring"
You can find one on the site below for $1.50 or so.
https://www.vintagesingersewing.com/catalog/index.php?cPath=42&osCsid=7697cebcf0714ac3da8b2c1101c98365
It's the last listing for machine parts.
Hope this helps, please rate this if helpful
thanks
moni
Posted on Sep 15, 2009
  • 980 Answers
SOURCE: I have a singer 503A. The bobbin winder will not
When you have the winder rubber on try and turn the winder by hand, if it does not move the chances are the winder has seized, if the winder wheel is moving but not the spindle then the grip (thread) has worn, if you cannot move the whole winder by hand and it has seized you need to get some WD40 and spray a few drops down the spindle, take an electric drill and put it over the top of the spindle and switch it on slowly and it will probably free it off, be aware of oil splashing out.
you mighjt get a digram from www.tandtrepair.com
Posted on Feb 24, 2010
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Jul 16, 2017 | Singer Sewing Machines
I have a singer Fashion mate 7256 and when I turn the machine on E 4 comes on the screen. I have looked in my book buy can't find any information on this code! Can you help m
E4 is a bobbin shaft error I believe. In order to clear the message, you need to clean the bobbin case and turn the machine on and off.
Also check the bobbin winder shaft. If it is pushed over when you try to run the machine you may get the error.
Jan 20, 2017 | Singer Sewing Machines
Singer error codes
I just downloaded and took a look at the user's manual at the singer site--I recommend you do the same, the manual is invaluable. On page 29, it says the the bobbin winder is in operation. Typically, you engage the bobbin winder by moving a shaft over--move it back into sewing position.
Aug 18, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
Sewing machine Singer Advance 7422, I try to fill a bobbin on the top of my machine. I put the bobbin in position and the shaft will not turn. The machine is treaded correctly and put in the right...
some machine, you have to push the bobbin winder spindle to the
right so that it will wind the bobbin, I have to on mine.
but if you've already done that then the machine needs to be checked
to see what wrong with the bobbin winder spindle
Aug 21, 2012 | Singer 7422
The bobbin shaft will not spin
make sure the bobbin winder spindle has been pushed to the right
if you've done that, & it doens't wind the bobbin then the machine
will need to be checked
My singer quantum 9940 bobbin will not fill even. What seems to be the problem?
There's a small screw on top of bobbin winder on your machine. Turn screw to adjust pressure where bobbin meets the winder when winder is pushed to right to wind it. Test with small turns until you are satisfied with appearance. Make sure nice, even fill- as you know, imbalanced bobbin will reak havoc. Jimmy
Apr 09, 2012 | Singer Sewing Machines
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
Bobbin winder won't spin
Singer 9410 I take it ??
More detail is always helpful here, saves time and guesswork.
Likely to be worn or broken Bobbin Winder Rubber...like a tyre that runs off the handwheel inside casing when moved to Right side position.
For future questions just ask for "BargainBox" via this link
http://www.wix.com/i08870/justask
Glad to help.
Cheers
Martyn
Bargain Box Fabrics
Oct 29, 2011 | Sewing Machines
Problem with winding thread onto the bobbin (small free- arm Singer 100 sewing machine). Once bobbin winder shaft is pushed to the right nothing happens-bobbin rod does not start turning so I cannot wind...
Aug 18, 2008 | Singer Featherweight 140Q
Singer 160 Anniversary Limited Edition Computerized Sewing Machine Logo
16 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
